Hello everyone!
It has been a couple of weeks since I last posted.
If you remember, I had trouble with my foundry melting brass. I decided that I needed a new burner. The burner I had was not well designed and did not burn completely or well hence the dramatic flames out of the top. Trying to save time I purchased a new burner. I had considered a forced air burner, but found a naturally asperated burner and decided to use that, keeping the system a little simpler. Well, I have not yet received my burner (nor have I received word other than payment hase been accepted, is this an oops on my part? ). I had consdered making a burner of my own, but I wanted to save time. I could have had it made by now. I may do that yet. Mine will be forced air, propane (LP).
Waiting, I decided to build a new foundry. I have not constructed it yet (waiting for the burner) but
I may start Tuesday if I do not hear from the burner guy. I am concerned about getting the burner hole the correct size.
The foundry will be a composit of fire brick and mortor with a sheet metal skin. The design was, done on SolidWorks (over kill). I cut the bricks on a table saw. It was easily done and as you can see, very nice results. This foundry has much thicker walls than most I have seen in the internet, though the few pros I have conversed with have foundrys more like mine (I copied). The other foundrys I have used lost an incredable amount of energy through their walls and were extremely hot, untouchable after they began to heat up. Brass having a higher melting point needs more energy to melt. The extra insulation saves energy, of course, making the melting easier and faster. The section in the pictures is 9 inches high, a diameter of 16 inches, with a 7 inch central diameter. The topp and bottom will add about 6 inches to the overall hight.
So, here are a few pictures for you. Regardless, this week I will be building the foundry so we can get this project going.
This is a bit frustrating for me too at times
I am hoping to post a video comparing the burners (if I ever get tthe new one)
As I said earlier, the design dimensions were to be 16" OD, 7" ID. After cutting the brick the ID and OD were within 1/8" of design. I was amazed. Done very well, but purely by accident. I wish fabracating always worked out so well!
Have a nice day!
