Hello Guys,
I have a question about the main motor connection.
In the manual says that by the left motor the blue wire is on top and the yellow
down and on the right motor is the yellow wire on top and de blue wire down.
Why is that not the same like the other tanks? Is that because there are
2 smokers in the KT?
thanks
best regards Yves
cables to main motors
- Been liked: 592 times
- Been liked: 15 times
Re: cables to main motors
Hello Yves
On the motors there should be a Red felt tip pen mark on one of the terminals the yellow cable goes to that one. You should end up with the yellows on top of the motors.
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
Thanks Lee for the info,
I got Mark already on the phone, because i need some parts, to order
and i ask him about the wiring yellow and blue, he said it donth matter
which collor is on top, if the motors run different from each other switch the yellow and blue.
regards Yves
regards Yves
