New motion pack
- Been liked: 525 times
New motion pack
My new motion pack turned up yesterday . It only took seven days from the UK to me . It all looks realy good . I will pick up my batterys on Friday . Then I can bench test it then away I go. Dale.
- Has liked: 1492 times
- Been liked: 1699 times
- Been liked: 10 times
- Been liked: 3712 times
Main Motors
Allan
The new motors are from a UK company called EMD. They are very similar to the Parvalux motor in terms of build quality, but offer an improved power output and are fitted with a more robust and easier to mount gearbox. It also gives us the flexibility of being able to source motors from more than one supplier.
At 12.30 pm today . I turned on my motion pack for the first time . Everything worked perfectly . I'm hopeless with R/C stuff . I checked everything five times before I switched it on . The pressure was on when I pushed the red button for the first time . So if I can do it anyone can. Whilst I had the motors out on the bench I thought I would see If the new motors and gear boxes would fit my Sherman . They don't as the sherman front gear houseing hits the top of the gear box . Dale
Mark,
Thanks for the reply, more than one supplier is always a good thing.
Dale,
I'm glad you got your motion pack working first time. Always a good thing, I'm fitting the motion pack in my Sherman at present but need to buy a radio receiver before I can test it out. It is straight forward if you approach the installation in a logical way.
Dale,
Allan Richards
