Miniature Fixtures. Nuts Bolts Screws Rivets Washers
Mike Stannard (toyrific)
Hi Guys
I have at last got the miniature fixture set completed with close to 40,000 parts sorted.
MINIATURE FIXTURES
M-FIX01 Miniature Hex Head Machine Screws and Nuts (450 pieces 18 Cents each) $80.00
M-FIX02 Miniature Slotted Flat Head Machine Screws and Nuts (420 pieces 15 cents each) $65.00
M-FIX03 Miniature Self Tapping Screws, Rivets, Washers and Lock Nuts (435 pieces 15 cents each) $65.00
Refills of parts available at prices listed in box description sheet.
Here are the sets.
M-FIX01 Miniature Hex Head Machine Screws and Nuts (450 pieces)
Note: Scaled nuts should only be used when they are seen, otherwise regular nuts should be used to save money.
M-FIX02 Miniature Slotted Flat Head Machine Screws and Nuts (420 pieces)
I have selected the slotted flat head screws so they can be used for both exterior detail and inside where not seen.
M-FIX03 Miniature Self Tapping Screws, Rivets, Washers and Lock Nuts (435 pieces)
Note, Brass self tapping screws should not be used in metal, the heads twist off to easily, these are for detailing and you should drill a hole and glue in place. They are fine for plastic and resin, but care should still be taken or you could twist the head off. For using all self tapping screws drill a hole just under the size of the screw and oil screw before fitting. I recommend doing a test on scrap material before drilling and using screws on your model.
Please e-mail orders using the part numbers above, for refills if you want to add them use the part numbers shown at the top of each section in the pictures above.
I have six sets of each in stock for immediate delivery.
Current orders will be mailed in the next few days.
Mike
