measurements
Posted: Sun Nov 27, 2011 5:50 am
by Ray Brown
g'day all. are nuts, bolts and holes in metric or imperial? also what are the sizes and thread for holes and bolts as i need to tap some of them to get a flush fit.
cheers in advance.
Re: measurements
Posted: Sun Nov 27, 2011 8:20 am
by Nick Farrugia
Hi Ray
All nuts and bolts in the kit are metric M2/M2.5/M3/M4/M5 and M6
Hope this helps.
regards nick
Re: measurements
Posted: Sun Nov 27, 2011 8:56 am
by Ray Brown
what about tap & dye sizes. i need to get the thread further to get the axle flush.
Re: measurements
Posted: Sun Nov 27, 2011 9:19 am
by John Fitzsimons
I got a set of metric taps and they are labeled m3,m4 ect. Mine had 2 seperate thread sizes but easy to check the correct tap using the gauge.
Re: measurements
Posted: Sun Nov 27, 2011 9:49 am
by leesellars
Hello Ray
What you need is a good quality tap and die set. From m3 to m12. Over hear in the UK a good set is in the region of £180.00. There are cheaper sets but they tend to snap and you don't want that. Also you need a cutting compound.
Top tip from my brother is use WD40.
Lee
