My M3 halftrack
My M3 halftrack
Gave my M3 a repaint last year and this is her at a local show.
She is painted up as "Commando Yank", a halftrack that served with 6th Armored Infantry, 1st Armored Division in North Africa circa early 1943. The original was one of 95 halftracks captured at the Kasserine-Faid Pass in February 1943. It sports the Ist Armored yellow stars and a rendition of the locally applied mud camouflage in random patterns. This was common practice at the time to break up the olive drab. It also has a copy of the "Commando Yank" cartoon in the same place as the original.
The other side of the halftrack. As you can see it is an early example with truck style headlights and brush guards. It is armed with a water cooled 1917 Browning 0.30 cal as the original. She also carries an original Afrika Korps "jerry can".
Here she is parked besides a "Mighty Antar" tank transporter - not mine! A case of little and large!
War-time photograph of the original "Commando Yank". Note the early tires on the wrong way round!
Superb photograph of a M2 halftrack crew serving with the 1st Armored near Souk el Khemis, Tunisia in November 1942. Look at all the different variations of unifrom. Most of the crew are wearing at least part of the winter combat uniform - it gets cold in the desert! The M2 at this stage of the war was mainly doing the job it was intended for - scouting, as here for example.
Just shows that a halftrack does not have to be plain old OD. Build a North Africa or even a Sicily halftrack and be different! Look at those uniform variations too!!
Hope you like the photos!
If you need a particular part photographed just PM me. I also have a M3A1 so I can take photographs of that too.
- Has liked: 1419 times
- Been liked: 1594 times
Tony,
Great pictures - especially the crew - at the moment I'm starting to pick up US uniforms and bits to make up my crew so the more piccies the better
I'm intending to convert my M2 to an M4 mortar carrier - kitted out for Tunisia or Sicily - so similar colour schemes to yours.
The refs I have seem to indicate an official painted scheme for Sicily, rather than daubed mud. It looks quite like Lee's Sherman in colour and design.
Are you building one of these half-tracks, or is a 1:1 scale one enough
Hi Adrian,
If you want to go for Tunisia the paint should be OD with or without the mud. The official two-tone scheme of sand paint applied over OD appears to only have been adopted for the invasion of Sicily, with surviving vehicles then going into Italy. Not sure how many M4's made it to Tunisia, as only 572 had been built by the end of October 1942, but units would have had them for the invasion of Sicily. I'll post some more period crew pics for you.
For an M4 during this period, as you probably know, the mortar should point to the rear as originally designed. It was only later that units such as 2nd Armored changed the layout so that it pointed forwards. You will also need to fabricate a skate-rail unless the Atek one already has it. Have several halftrack references if you need them.
Yes I have a Atek halftrack on order - it would be rude not to!!!!
Looks like Sicily then, as that's my favourite colour scheme.
Yup. I also need to make the mortar (I'll probably use a 60mm until then) and give the M2 a back door.
As Dave Dibbs has already shown the prototype for his skate-rail gun attachment I'm sure hoping there's a skate-rail !!
I'd be interested in a list as I've started picking up quite a few books but there are bound to be some I've missed. I've tried getting some of the original Technical Manuals but the originals never seem to turn up and the copies seem hugely overpriced
Pics for Adrian
Hi Adrian, more reference for you. The photograph below is the same halftrack and crew as the one at Souk el Khemis, previously posted. Note that the guy on the right appears to be wearing a ANJ4 flying jacket. Also note all the kit strewn about the place.
This is a M2 of the 601st Tank Destroyer Battalion at El Guettar March 1943. Note the coats and winter combat (tankers) jackets. Also note the M3 75mm GMC in the background.
A typical halftrack during the invasion of Sicily. This one belonged to Company B, 41st Armored Infantry Regiment, 2nd Armored Division.
M4 halftrack during stateside training.
One for you German fans! A captured M3 early 1943. In the background is a Sd.Kfz.263 radio vehicle.
- Has liked: 127 times
- Been liked: 758 times
Thanks Bob!
They drive well, I can out-run a GMC in mine! Being tall however it can be a real pain in the neck, literally, as I have to duck down a bit to see through the windscreen!
I've said it before, if any of you super-detailers want pics posted just let me know, I'll be most happy to oblige 'till then I'll post this just for Gill. This little chap is one of my favourites. Ahhhh!!!!!
Thanks for the extra pics Tony, though I'm not sure about the one of Boris Johnson...
I'm reading the "Hell on Wheels" history at the moment, and may well end up doing one of their vehicles.
Are you aware of any pictures/documents showing the additional markings/stencils these vehicles will have carried ?
- Been liked: 3480 times
Hi Adrian,
My knowledge on the Second Armored Div is sketchy at best. As far as I can gather in North Africa they differed from 1st AD by having white stars, not yellow. In Sicily you can't really go wrong if you copied 'Billy Brown' above and added unit markings on the bumpers if you wanted to. In Europe they appear to have used a two-tone camouflage, possibly black over OD, although I have heard it may have been brown over OD. They also used large vehicle numbers on the sides, apparently painted in yellow. For more information you could try http://www.2ndarmoredhellonwheels.com/
I'm sure the guys there will be able to help you.
Here are some M4 halftrack 2nd AD pics that I have. This first one is a famous photo of "Lord Eppie" belonging to 41st Armored Infantry in April 1944. Note the gas reacting circle of paint around the star on the bonnet, and the aiming post above the rad. Also note that the paint appears to be plain OD. Either not all Htracks had the two-tone camo or it was applied shortly before D-Day.
The next is the interior of the same vehicle.
This one was taken at Amonines, January 1945.
Hope they help.
Hi Gill, glad you liked Ignacio. He is one of the more adventurous ones!
Hope they help.
2nd Armored
Hi Adrian,
My brother came round today with some of his books on the 2nd Armored and stuff. We found this photo which was taken during a practice for the invasion of Sicily. It is 2nd AD halftracks coming off a LST. Look close and you can see the two-tone camo. Don't fancy doing that turn on the ramp in rough weather!
We also found this fantastic photo of a halftrack in Tunisia, it is probably a 1st AD command vehicle with lots of great stowage!
Now for a bit of self-indulgence, two halftracks in firing positions, one of which is a T19, oh joy!!!!!
Hope you guys get a kick out of these photos, I know I do!!
Sure am Adrian! My hope is to have it at Beltring this year and put it on the desert display near the LRDG guys, or even the Afrika Korps chaps as Commando Yank was one of the captured ones. Any of you Armortek owners can come over and get a ride!
I live on the Suffolk/Essex border so if anyone wants to pop round they will always be welcome, you never know you might even get a bacon buttie to boot! At this moment it time I've got one wheel hub apart so she is not moble but you can still crawl over it and take photos.
Cheers!!!
Cheers!!!
I've not made it to Beltring yet. I may yet manage it this year, especially as SWMBO has agreed to accompany me to Militaria this weekend
Hmmm, a brother-in-law lives in Marks Tey, I wonder if I could combine the trips
What do you use for a Haynes manual ? And spares for that matter ? Are there sources in the UK or do you have to ship it all from the USofA ?
Might see you at Stoneleigh then!
A huge lot of parts and vehicles of all types were left in Europe after WW11. France had a lot of halftracks. Parts are still available NOS (new old stock) from dealers but are getting harder to find. A lot of parts now available in the states have recently gone back from European dealers. Tracks are around, mostly ex-Israeli stock now. As for manuals reprints are plentiful. One thing I'm having trouble finding is a 105mm howitzer for the T19, without that it is difficult to start the restoration as the mount needs to be 100% correct. So if anybody has got one just drop me a PM!
