Hi Roland.
My 2003 Mid Tiger now has a new floor, suspension bars, shafts and axles.
Next job is to convert all the wheels to use the current spacer system. I'll post some pictures once there are enough parts assembled
My idea with the pannier fillet is to have the part cut from 2mm aluminium and epoxy it into position, maybe with a couple of positioning holes. I'm having new aluminium pannier floors cut as well, so I can line the holes up on the two parts to make installation of the fillet easier.
I've roughed out the length and scallops, using Tim's dimensions (Thanks Tim
) for one side and the old steel part from the Early Tiger for the other:
- Pannier Fillet 2.jpg (25.97 KiB) Viewed 3984 times
I hope to get to Bovington tomorrow, (oops, today
) and will try and take a succession of photographs along each side of the Tiger so I can stitch them together and make up composite pictures of the whole of each of the panniers.
