SMOKE
Posted: Thu Sep 29, 2011 9:47 am
by Jan_Donadoni
Hello,
I have found an interesting idea for the smoke generators.
Actually the should be operated with oil that is, the whole system should rely on "heating" up the oil, as much as I understand.
Water based smoke generators should work with "cold vapor" that is : generated through the use of ultrasounds.
I have found a producer of fluids for professional smoke generators (smoke seen in movies or in the discos and so on).
They provide many different fluids for different effects.
As much as I understood they provide water based fluids, BUT these fluid operate on the "heating" principle, so they should be compatible with Armortek's standard oil based smoke generator.
Here's the link http://www.froggysfog.com/category/10-fluid.10-fog/
Maybe they could provide us proper smoke fluids (already thinking to the T-34s which produced lots of smoke)
Re: SMOKE
Posted: Fri Sep 30, 2011 10:02 am
by Marcel de Groene
Hello Jan,
I use that kind of fluid for some time now. Very satisfactory, but the residue still looks like oil, allthough it's water based. Smoke production is good enough though.
Re: SMOKE
Posted: Fri Sep 30, 2011 10:40 am
by Jan_Donadoni
Thanks for the info.
I will try to get some here in Europe.
Where do you get yours?
Re: SMOKE
Posted: Fri Sep 30, 2011 12:41 pm
by Marcel de Groene
Hello Jan,
The company were I got my fluid from has closed down. You better try to find this:
Eurolite Smokefluid X
http://www.eurolite.de/eur_artdetail.ph ... 354&lang=E
Great German Quality so should easily fit into our "cats" :wink:
For Italy, check this one out: http://www.shopmania.it/videoproiezione ... l-31180589
