Hi fellas.
Well I suppose I will have to admit that I have been putting this one off a little bit, the more I looked at it the more problems I seemed to find but here goes lets see what can be made of it.
![100_1156.JPG](./download/file.php?id=798&sid=00361b442a9c2e13c1e16a0589649726)
- 100_1156.JPG (2.48 MiB) Viewed 10154 times
Once most of the model was stripped back to the bacic chasis I started going round tightening things up, the above picture shows a bit of a problem the pins that hold the bogies on had plenty of thread lock on them and needed to come off so get to the countersinks underneath that were very loose, a bit of heat from the blowtorch soon had the pins free and everything put back in place.
Then I noticed the rear bogies on one side did not travel back as far as the other side did see the next picture.
![100_1157.JPG](./download/file.php?id=799&sid=00361b442a9c2e13c1e16a0589649726)
- 100_1157.JPG (2.29 MiB) Viewed 10154 times
it turned out thet when the bogie moved on its pin it was catching on the brackets below, 5 mins with the power file sorted this out quick style.
![100_1158.JPG](./download/file.php?id=800&sid=00361b442a9c2e13c1e16a0589649726)
- 100_1158.JPG (2.63 MiB) Viewed 10154 times
In the next picture the parts are re painted and you can see that the travel now matches the other side.
![100_1159.JPG](./download/file.php?id=801&sid=00361b442a9c2e13c1e16a0589649726)
- 100_1159.JPG (2.37 MiB) Viewed 10154 times
Finally a picture of the chasis all tightened up and with a coat of etch primer.
![100_1160.JPG](./download/file.php?id=802&sid=00361b442a9c2e13c1e16a0589649726)
- 100_1160.JPG (2.8 MiB) Viewed 10154 times
More to follow soon, thanks for looking.
Cheers Paul
![Wink :wink:](./images/smilies/icon_wink.gif)
