Build Problems And How To Deal With Them?
Posted: Mon Jun 13, 2011 11:59 am
by Darryl Vernon
On these boards, there are many tanks being built to an extremely high standard, and there are many helpful tips included in these builds when it comes to making our tanks look realistic.
But, as a newcomer to this hobby, I've come across a fair few problems that many others must have had, but hardly any mention is ever made, if at all, concerning these problems, and how to get around them.
I find that the instruction book, is not as clear as it could be in some sections, and I find myself scratching my head in frustration, trying to work out how parts go together.
Here's a classic example:-
Page 24 - Pack 9 Deck Detail Parts
According to the instruction book, the Fan Grill(CH0642) and the Fan Cover(CH0627), are fitted to the fan cases, using M3x6 Hex bolts.
There is no mention of how many fasteners are used, so I assume it is 1 per fan, as there is a hole in the centre of the grills.
Where does the bolt go?
There is no hole in the centre of the Fan Case. :?:
Another problem that I've come across, that I can find no mention of, is that the two cast parts that make up the main gun Mantlet, (CH0438 and CH0409) have holes that don't line up, by about 1.5-2mm.
The instructions say to 'File any extra clearance that may be required on these sand cast items', but I cannot get inside the outer mantlet to file away, as it is virtually inaccessible, and I'm loath to file as much as 2mm from the inner mantlet, as that seems a lot to take off from one part.
How did you guys get around that problem, as I can find no mention of this in any other posts?
The Turret Ring (CH0405), is an extremely tight fit when placed into the Turret Bearing(CH0117).
So tight in fact, that it is impossible to rotate the ring in the bearing by hand.
When the weight of the turret is on there, will it then rotate ok?
Does the tightness of these parts, not put too much stress on the motor and Ring Gear?
Are they supposed to be this tight? It's not mentioned anywhere.
I've had a few other times when I've been stuck, but managed to bodge/work my way around it eventually, but as a newbie to these kits, with absolutely no engineering skills whatsoever, I do find the instructions could be a little clearer in some areas.
I'm not trying to be negative here, I'm just trying to highlight some of the things that I've had problems with, and that no one else seems to mention, either in the build threads or elsewhere.
This place is a font of knowledge, so let's see more posts on how to get around those little frustrations that one (especially newbies), can come across while building one of these lovely kits.
Ta for reading. :wink:
Posted: Mon Jun 13, 2011 5:49 pm
by John Fitzsimons
I am also building my first Armortek Tiger 1. I agree the instructions can be a little vague. I have a few parts for which I know there are fasteners but the instructions do not mention which ones to use. I have found the builds on the forum to be the best and clearest source of information and found that posting a question when in doubt usually gets a clear and speedy reply.
I still have no idea how to load the blank firer and not looking forward to tackling the electronics.
Somtimes you just have to read the instructions a few times slowly before it all comes clear.
The grills on the Tiger are tied on with wire as far as I know. Maybe the Panther grills are the same.
Posted: Mon Jun 13, 2011 7:42 pm
by Luca Fossa
Hi Darryl, i try to help you altough Mark is more indicated to do this.
Regarding the fan grill in fact they doesn't have any hole in the middle, probably they was designated to fit the other type of fan adopted on the late "G" panther. In real the grill was fixed with iron wire or soldered directly over the fan. If you look to my post i have decided to fix them with iron wire. You can fix the grill also with a bolt in the middle, but this solution is not properly correct.
The gun mantlet require a good amount of patience to be adapted. You have to work on the round extremity of the inside mantlet (CHO438), by removing the excess of material until your holes fits togheter. Don't touch absolutely the holes by enlarging them or whatsoever thing. When your holes will be ok probably you have to remove some more material too to have a fluid movement of the mantlet (CHO409).
In my panther i have fixed the turret bearing (CHO117) by screwing it to the upper hull (CHO113), then it was filed carefully. Try the movement with all the turret assembled and you will se the movement will be ok.
Hope this can help
Luca
fasteners
Posted: Mon Jun 13, 2011 7:49 pm
by yves mouton
Hello Darryl,
I think John is right about how to connect the grills on the fan grills.
I also used fine iron wire to connect my tiger 1 mesh grills on the deck grills.
regards Yves
Posted: Mon Jun 13, 2011 10:02 pm
by John Fitzsimons
My Tiger Gun Mantlet also required a great deal of filing before it would move freely. It was one of the first things I tackled. I was concerned at the time but now just accept these things as part of the build process.
Posted: Tue Jun 14, 2011 11:46 pm
by Darryl Vernon
Thanks for the replies guys.
Luca, thanks for the detailed reply. I've looked at the pictures of your grills, but cannot make out how you've attached them with the wire.
In the meantime, when about to bolt the turret gear etc, I came upon another problem. :roll:
Instructions:-
Having got everything ready to assemble, I find that the M5 x30 bolt is not long enough.
It's this sort of thing, that's beginning to make me a bit fed up, to be quite honest.
I set myself up, and get everything sorted out ready to do some assembly, only to find this sort of thing, and I then end up packing it away again in frustration.
Posted: Wed Jun 15, 2011 5:04 am
by willie leonard
Hey Darryl,
Hang in there.I had the same problems your having. First the mantlet.I used a hand grinder with a medium grit pad and took off a little bit at a time of the rounded front of the inner mantlet until the holes lined up.Once the outer mantlet is on you'll won't see the grind marks anyway. On the turrent bearing I took some extra
fine emery clothe and just sanded the inside of the bearing until it
fit snug but loose enough to turn easely.It didn't take much sanding to get to this done. Add a little white litheium grease and your good to go. I, like yourself,have limited engineering skills and at times get frusterated,however i've found that any problem
I come across there is always some way around it or someone on this forum thats more than happy to help.
Posted: Wed Jun 15, 2011 5:34 am
by Luca Fossa
Darryl look carefully
About the screws to fix the rings under the turret is enough to buy some screws more long than those provided in the kit.
Cya all
Luca
Posted: Thu Jun 16, 2011 12:22 am
by Tim Bowman
Hi Darryl
Not that this comment will help you but I can say that without a doubt, the second Armortek kit you build goes so much easier. My Panther was a learning experience too and I am not a mechanical/machining type of person. I think the only fit issue I had on my Panther was the left side of the turret where it attached to the rear plate of the turret. This was easily solved with some minor filing.
In regards to the mesh covers for the cooling exhaust fan guard, in real life they are tack-welded to the covers in four spots around the perimeter. HArd to do on the etched screen with it's minimal thickness though. The older kit had the hole in the guard for the fastener but it's not on the real one.
Kindest regards
Posted: Thu Jun 16, 2011 12:41 pm
by Kent Wiik
Darryl Vernon wrote:I could find no info anywhere, as to how they were fitted in real life
Hi Darryl,
Tons of information here at the forum:
http://www.armortek.co.uk/forum/viewtop ... &start=120
(scroll down a bit)
"The real mesh ring was attached to the shroud with welds at the bulbs so fake welds (1/â€
Posted: Thu Jun 16, 2011 3:59 pm
by Darryl Vernon
willie leonard wrote:Hey Darryl,
Thanks Willie. I was a bit concerned about sanding the bearing, but wil do that now.
Luca Fossa wrote:Darryl look carefully
Cya all
Luca
That photo is very clear. Thanks Luca.
Tim Bowman wrote:Hi Darryl
Kindest regards
Pukka grills Tim. Who makes them?
Hi Darryl,
(scroll down a bit)
I have read through loads of the posts over the last few months, but I somehow missed that.
In my defence, there are thousands of post to go through. :)
Kent Wiik wrote:"The real mesh ring was attached to the shroud with welds at the bulbs so fake welds (1/â€
Posted: Thu Jun 16, 2011 4:25 pm
by Tim Bowman
Hi Darryl
The ones on my Panther are from Mike Stannard. He can be contacted through PM or email from his posts here on the 'Craftsman' section.
Good luck with your Panther.
Posted: Fri Jun 17, 2011 5:51 pm
by Robert E Morey
Hi Daryl,
Don't get frustrated, just keep plugging. There are lots of minor fitting and modifications to be made, but you should be able to find help locally or on the forum here. We've all been where you are. Take heart you can see what these models can become with some patience and effort.
hang in there,
