Late Tiger Gun Barrel Assembly/Blank Firing Option Pack
I am assembling the Blank Firing Option Pack and have found the steel threaded steel Gun Tube to be VERY tight into the alloy threaded gun barrel and Mag Bracket. Have tried using Carborundum paste to try cutting a way through the threads but to no avail. Anybody experienced the same; if so any solution ? I don't want to distress or strip threads ! [/b]
- Has liked: 6 times
- Been liked: 813 times
- Has liked: 4 times
Christopher
May I suggest that you give Mark a ring for advice. I believe that the threads have been made specifically tight to comply with the UK firearms regulations and to prevent any foreign bodies being inserted into the barrel. I had the same problem with one of the first systems sold and Marks advice sorted out the problem for me. It is an easy fix.
regards
Colin
regards
Colin
- Been liked: 3700 times
