Concerning binding drive gears.
Posted: Sun Mar 27, 2011 10:27 am
Once I'd fitted the gear cases to the front sides of my Panther, I noticed that they were binding on the hull.
I then read the 'Official Technical Advice from Armortek' section of the forum that deals with this problem, printed it off, and am now in the process of re-doing the driven gear cases as per the advice.
My question is, if all else failed, would it cause a problem if I made up a thin gasket between the hull and the case, to just get that extra minute clearance?
[/u]
[/u]
