Page 1 of 8
Dales mid tiger 1
Posted: Fri Dec 03, 2010 11:08 pm
by Dale jordan
I started my 2010 Mid Tiger 1 kit number 019 this week . For a change I'm building the turret first , here are some photos . I've added a 3mm x10 mm shelf inside the turret rap . Milled two slots in the front inside plate for the roof tungs that are bolt to the turret roof front edge ... Dale
In this last photo I ended up with about a 1.2mm gap all the way around the turret roof this was the best i could get it to fit !! how did the other mid tiger owners go with their gap??
Posted: Sat Dec 04, 2010 1:13 am
by Robert E Morey
Dale,
Nice to see you back at on another Tiger! These additions are excellent and a good idea for any builder, not just Tigers. Great to see you back,
Kind regards,
Posted: Sat Dec 04, 2010 2:36 am
by Dale jordan
Thanks Bob. This kit is going to be great to build after my early tiger . Just finished my spring loaded lifting lug , quick release latch ..Dale
turret roof
Posted: Sat Dec 04, 2010 10:52 am
by yves mouton
Hi Dale,
Thats also a good idea to secure the turret roof,
i used magnets to secure the roof.
I see that you are using a spring on the back of the turret wrap,
gives that no problem to pul back the turret lug if you put the
stowage bin on? I wil post you a picture of the turret roof.
regards Yves
Posted: Sat Dec 04, 2010 3:10 pm
by Brian Leach
Dale,
That is a very nice looking, clever way of securing the roof
Good work
and thanks for sharing!
Brian
Posted: Sat Dec 04, 2010 9:45 pm
by Dale jordan
Thanks Yves and Brian . I did this on my early tiger it works well , there's enough room when the turret bin is on to pull back the spring on the quick release ...Dale
Posted: Sun Dec 05, 2010 6:17 am
by Dale jordan
My Last day of my holiday today . So I had one more go in the shed .. Here are some photos of the wipers on the front bulkhead ..Dale
Re: Dales mid tiger 1
Posted: Sun Dec 05, 2010 6:48 pm
by Luca Fossa
Dale jordan wrote: In this last photo I ended up with about a 1.2mm gap all the way around the turret roof this was the best i could get it to fit !! how did the other mid tiger owners go with their gap??
...Filled with a false weld, as in the real on the rest.
Great and very nice work Dale, as always.
Cya all
Luca
Posted: Sun Dec 05, 2010 7:17 pm
by Christoffer Ahlfors
Very nice looking and nifty idea! :D
My gap was much smaller - ranging from zero to 1 mm. The instructions call for attaching the mounting sockets to the roof first and then pulling tight from the sides. Done this way, the turret wall is in fact pulled tight around the roof.
/Chris
Posted: Sun Dec 05, 2010 7:29 pm
by Steven Day
Nice work Dale, I would never of thought of securing the turret roof like that.
Posted: Sun Dec 05, 2010 10:51 pm
by Paul Morris
And the crickets looking good as well :lol:
Posted: Sun Dec 05, 2010 11:52 pm
by Paul Butler
Hi Dale,
Just a quick question, I have yet to start on my 5 year old mid tiger turret I ask would in your'e valued opinion, think whether it may be wise to upgrade from the cast turret to the formed one? Following the build with great interest!
Regards Paul
Posted: Mon Dec 06, 2010 1:05 am
by Tim Bowman
Looking good Dale(as always). Very nice.
best regards
Posted: Mon Dec 06, 2010 1:08 am
by Dale jordan
Good to here from you Paul ... I found the cast turret was fine . Just hat to belt sand the outside square and move the vison ports . \The good thing about the cast turret was that it had a machined shelf for the roof to sit in . I would cut out a new alloy roof for it !! as the kit one rusts to much and the loaders hatch needed moving forward .. Paul after five years have you pick a start date ? Dale
Posted: Mon Dec 06, 2010 7:57 am
by Phil Woollard
Hi Paul, 5 years! Cheers Phil
