Page 1 of 2
One idea for all us
Posted: Thu Oct 28, 2010 9:45 am
by Alfredo Campanini
During the construction of our tanks, we need to keep the hull raised, higher and higher, until the assembly of the tracks.
It would be nice to have a small platform with articulated arms, which could be operated with a worm by a simply cordless screwdriver or drill.
I am not able to make a drawing, but maybe someone can take this idea and develop it.
Posted: Thu Oct 28, 2010 6:15 pm
One of these:
http://www.amazon.co.uk/Sealey-MC5908-S ... B001SFVG5O
But make sure you get one with a nut to turn, rather than a handle, otherwise you can't operate it on a bench
Posted: Thu Oct 28, 2010 6:48 pm
Thanks Adrian, it's just that and now I have to check the size of the
upper deck, that fits under the thank
Posted: Thu Oct 28, 2010 9:14 pm
by Ad Wouterse
Hi Alfredo,
Here are the specifications
Specification
Model No:....................................................................MC5908C
Capacity:..........................................................................450kg
Minimum Height:..............................................................85mm
Maximum Height:...........................................................365mm
Width:.............................................................................230mm
Length:...........................................................................380mm
I have a similar scissor lift (see picture)
The black clamps are optional. The support flanges ensure a safe mounting.
The price was only Euro 49,- .
Similar tools must be available in Italy too.
Posted: Thu Oct 28, 2010 9:20 pm
Thanks Ad; there is always someone who is ahead of us
Motor Cycle Lift
Posted: Sun Oct 31, 2010 10:27 pm
by Steve Stuart
Hi All
The Motor Cycle lift is a very useful purchase.....
I have just used it to lift two 60Kg solid wood High Level Corner Units for our new kitchen into position all on my own, I am a 10 stone weakling who learnt the hard way on a farm, shifting 1cwt sacks of corn when student! Just because it is bought for the tank these things can be used for other purposes, which helps to justify your interest in this hobby!
Posted: Tue Nov 09, 2010 4:55 pm
Hi dear friends,
Comet and I thank you very much for your help
Posted: Thu Nov 11, 2010 10:58 am
by Tom Jensen
Hi, I have the same lift, did you make that long extension yourself? Can you explain how? Thanks!
Tom in Virginia
Posted: Thu Nov 11, 2010 2:20 pm
It is quite simple; I removed the spring pin and removed the crank, then I drilled a copper pipe (copper is not ideal, but it was what I had in the workshop) ø 6 mm. the two ends. One part is inserted into the pivot on the platform and fixed with M6 bolt/nut, in the opposite hole just insert a screwdriver for the motion.
Posted: Sun Nov 14, 2010 10:58 am
by Fred Lopian
Hi Ad and Alfredo,
that is a brilliant idea. I have sought for a long time such a part.
Where can I buy this?
I cannot find this in the internet.
Many thanks,
Fred
Sealey MC 5908
Posted: Sun Nov 14, 2010 11:26 am
Hello Fred,
I had difficulty finding a supplier who ship in Italy, even Amazon, I finally found this
www.toolsdirect2you.co.uk
If you have problems you can contact
Tony Littleford <
tools.direct@yahoo.com>
Service very quick ad satisfactory by TNT.
Posted: Sun Nov 14, 2010 1:03 pm
by Fred Lopian
Hello Alfredo,
many thanks for the information. I will immediately test this on Monday.
I wish you a nice Sunday.
Fred
Posted: Sun Nov 14, 2010 1:56 pm
by Fred Lopian
I found another dealer in Germany.
http://www.louis.de/index.php?topic=art ... r=10003265
Thanks for the help.
Fred
Posted: Sun Nov 14, 2010 2:03 pm
Very well Fred,
I think it will be easier for you.
Posted: Sun Nov 14, 2010 3:55 pm
by Ad Wouterse
Hi Fred,
Here is another German supplier, but with a much lower price:
http://www.household-discounter.de/such ... &x=28&y=10
