Benedini Decoder
Posted: Sat Sep 25, 2010 6:34 pm
by Jeff Hyder
Hi Guys,
I wonder if you can help with a few pointers.I am thinking of investing in an 2.4Ghz 7 channel Futaba.Is it possible to program up the Transmitter to access the 12 sounds from a Benedini Module or do I have to use a Decoder?.If the Transmitter cannot be programmed can I connect the Decoder to one of the Futaba's proportional channels as I have done with my old Sanwa VG400.My sound module is aready programmed up Decoder.Hope this makes sense.!
Many thanks Jeff Hyder.
Posted: Sun Sep 26, 2010 11:39 am
by Mick Regan
Hi Jeff
You can use the "toggle switch" control using either one of the joysticks or the 3 position switch on the Futaba 7C, but by far the easiest wat to control it is to fit the Benedini rotary encoder to channel 6. For a step by step guide, go to
http://www.armortek.co.uk/Forum3b/viewt ... f=2&t=1716
Hope this helps
Mick
Benedini Decoder
Posted: Sun Sep 26, 2010 12:35 pm
by Jeff Hyder
Hi Mick,
Many thanks for answering my questions and the thread to the guide photos on how to do it.Useing the Decoder is the way to go if you want access all 12 sounds so I will have a bash at it when I get my Futaba.
Thanks again Jeff Hyder
