Barrel rear
Posted: Mon Aug 02, 2010 11:11 pm
by David Da Costa
Are people just epoxying the rear part of the gun barrel into the gun base?
Posted: Mon Aug 02, 2010 11:55 pm
by Paul Morris
Hi David,
In the builds I have done I have drilled and tapped a hole for a 4mm grub screw to retain the barrel in the tube.
Cheers Paul
Posted: Tue Aug 03, 2010 12:12 am
by David Da Costa
Thanks Paul.
It was actually the the tube being retained in the gun mount on the turret that I was referring to.
gun tube
Posted: Tue Aug 03, 2010 8:49 am
by Nick Farrugia
hello david
on my pz111 the large tube that fitted into the gun mount thats on a
pivot. i tapped through the pivotting mount and into the large tube to secure
them both together ,the actual gun barrel i just wraped masking tape around
it so it is a snug fit.At sometime i am hoping to get it to recoil and fire a blank, so didnt want to fix the main barel in perminantly.I think this is what paul has done.If you drill it on the underside of the pivot then you wont know its there.
regards
nick
Posted: Tue Aug 03, 2010 2:14 pm
by David Da Costa
Got it.
That's what I will do.
Thanks Paul and Nick.
