MG
steve winstone
Been liked: 46 times
MG
Post by steve winstone »
Hi All,
I decided to machine up the MG to fit LED plus a servo lead, as the 3V bulb does not work with the Benedini Sound system. The cost of the MG will remain £16.00 if you want to fit your own LED. and £18.50 if you want it complete. Those with existing MG that has not been machined, I can supply the lead LED plus 2 pieces of fibre optic, 1.50 and 2mm which should fit existing barrels on the MG. All you would need to do is push the LED at the end and put the fibre optic down the barrel. This will also cost £2.50.
Below see photos 1] with cable fitted 2] Barrel with cable pushed up and the 2 fibre optics 3] fibre optic when lit up.
1]Image
2][/img]Image
3]Image[/img]
Great news Steve! Thanks for doing that.
email coming soon. :D
Rich Stinchcomb
Has liked: 3 times
Been liked: 1 time
Post by Rich Stinchcomb »
Very nice; I have to have one of those barrels.
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
Chang
Has liked: 16528 times
Been liked: 487 times
Post by Chang »
Hi Steve,
Very nice upgrade! Glad I have had it a while ago. Now I can do the same thing! :D
Steve should I use the 24V main power or one single 12V battery as the power source? :?:
Thanks!
Lerh Chang
steve winstone
Hi Chang
If you have the old MG with the bulb in it, it will not fit the benedini sound system. You will need the upgrade which is a 20" servo lead with a 3V LED on the end and the fibre optic which comes with the lead. see photos above.
Chang
Post by Chang »
Yes Steve,
Sorry I am not knowledgeable on this area. Please allow me asking some simple questions:
I have bought myself 3mm LED and servo leads. Do I really need the fibre optic? :?:
And as you said, the LED is 3V only. Does it need a independent 3V battery set, or can be operated by 24V or 12V major battery? :?:
Thanks and best regards,
Lerh Chang
steve winstone
Hi Chang,
Yes you do need the fibre optic to put down the inner barrel, as the lead is to thick to go down into the inner barrel. To make it fit you have to take the MG apart and do quite a lot of work to make it fit. The easiest way is to put the LED with the lead up the barrel and push the fibre optic at the other end, this way you do not need to do any work to the MG. Then connect the lead to the benedine system.
Chang
Post by Chang »
Hi Steve,Thanks for the advice.
Do you mean push the already wired LED into the end (left hand side) of the gun barrel, then insert the fibre optic into the muzzle (right hand side of the barrel) until they are connected? (See your photo here.)
Do they need to be glued together? :shock:
Lerh Chang
Dale jordan
Been liked: 497 times
Post by Dale jordan »
Thanks Steve . Today I found some time , to test your LED and fibre optic .. It works real well !!! great job . Just plus and play . Dale
Chang
Post by Chang »
Hi Steve,
I would like to buy the MG only for a friend of mine in Taiwan. I know the price is still £16.00. I will pay you via the Paypal.
Please tell me how much more for the postage and handling fees, and/or the Paypal's cost, etc. I will do it right after receiving your quote.
Thanks in advance.
Lerh Chang
