Hi Guys
The Tiger 2 Sternantenna D set up is basically the same as the Tiger 1 with two differences. The armored base is taller and the extension mast brackets are different as they have to allow for the sloping side of the KT. To put this into production I only have to make the taller armored base and the mast brackets, All other parts are available from the Tiger 1 SD antenna. Another part that will be included in the set will be a round angled plate to mount the 1.4 m antenna on the turret which is part of the command tank antenna set up.
I am offering this as a deluxe set complete with extension mast and fittings, extension mast stowage tube and the mast brackets. It will also be available as a basic set with only the base set up and the star antenna. Both sets will include the angled base for the turret antenna.
These sets will not be available in kit form.
TT18C Tiger 2. Sternantenna D Basic Set $125.00
TT18D Tiger 2. Sternantenna D Deluxe Set $250.00
Let me know if you are interested.
Sorry some of the pictures are not good quality, these were taken several years ago before I got a better camera.
Mike
