Hatch hooks Fasteners?
Posted: Fri Jun 25, 2010 8:13 am
by Dan Williams
I was wondering what fasteners fit the hatch hooks? I measure 3M x 10mm Pins. This hook hooks onto the side rear covers.
I did not see this detail in the book.So I wonder what other builders used.
Dan
CE0167 hatch hooks
CE0119 side rear covers LH & RH
Posted: Tue Jul 20, 2010 2:01 pm
by Steven Day
Hi Dan,
I see that no one's replied to your message, and like you, I was waiting for some knowledgeable person to reply.
While you've been waiting, have you found the answer yourself?
I'm not starting my build properly until October this year, but I couldn't resist loosely bolting the hull together and then started playing about with the rear deck, and like you, I couldn't find any fastenings (bolts or pins) for the hatch hooks.
hatch hooks
Posted: Tue Jul 20, 2010 6:20 pm
by yves mouton
Hello Dan
I used 3mm brass for the pins,you bow the pins a little in the middle an than you used a little hamer to put the pin in the holes,
so the pin fit in and dont come out. If you use loctitte becareful that you dont glue the hooks
Best regards Yves
Posted: Mon Oct 11, 2010 9:04 am
by Steven Day
Hi Dan & thanks Yves for the pin idea,
Now that I've started my build, I've been checking out some books, and it looks as if these hooks are bolted through with a castlated nut on the real thing.
I know a few 1/6 suppliers are selling the castlated nuts and finding an M3 bolt shouldn't present a problem.
Posted: Mon Oct 11, 2010 5:21 pm
by yves mouton
Hi Dan,
I think that the 3M*10 pins are for the front mudguards.
Best regards Yves
Posted: Mon Oct 11, 2010 8:29 pm
by Christoffer Ahlfors
I heartily recommend this fellow:
http://www.knupfershop.de/
Wonderfully looking bolts and fantastic customer service!
/Chris
Posted: Mon Oct 11, 2010 10:23 pm
I can't help with the correct fastener but these are a couple of photos I took of the Bovington Tiger as it was displayed at TankFest:
Posted: Tue Oct 12, 2010 12:14 pm
by Steven Day
Hi Chris,
Thanks for the web link. I think I'll have to brush up on my school boy German.
Posted: Tue Oct 12, 2010 12:26 pm
by Steven Day
Thanks Adrian,
That's the money shot. In all the pictures and illustrations I've seen they never show you the head of the bolt, which looks more like a pin with a threaded end, and makes perfect sense.
I'm trying to rearrange work so I can drop into Bovington and get as many pictures of their Tiger 1 as I can, especially around the rear deck. I desperately want to look at all the fixings and the heights of the air grills to the engine hatches etc.
Posted: Tue Oct 12, 2010 7:59 pm
Wonderful closeup - thanks!
/Chris
