Double posting.
Has liked: 1467 times
Been liked: 1642 times
Double posting.
With the recent problems with this forum, I've found that the error it gives when submitting a message usually happens after the it has been posted correctly.
So, rather than using the back button and clicking the Submit button again, it is probably better to open another browser window/tab and checking whether your message has been posted, before trying again.
Hopefully, this should reduce the number of double postings we've been getting recently :D :D
Derek Attree
Has liked: 219 times
Been liked: 198 times
Post by Derek Attree »
Hi All
Its happened to me the other day,
Gill could there be a way to delete a double post under the edit button if you
do this.
Derek, there's a little X in the top corner of your own postings - this is the delete button.
I believe it will only work as long as no-one has posted to the thread after your message - like I've just done to this one :oops:
Derek Attree
I would have thought in Edit mode you should be able to delete your own postings at any time.
