control box help????
hiya lads, need abit of help please? took my tiger out today, and now and then it would turn off, when i went to turn her on the green light would only flash then turn off again, after about 6 goes,it started to flash red a few times then went off again, then after a few more goes would start. it did this a few times today, so have placed her to bed, i cant seem to see anything wrong, anyone elese had this?? or know what it could be?? thanks fellas, glen
- Has liked: 1480 times
- Been liked: 1685 times
- Been liked: 3689 times
Hi glen
Adrian is 100% correct. It sounds like you have a bad or loose connection between your batteries and your power supply module/fuse box. Check your connections and apply a little vaseline to the battery terminals if there is any sign of corrosion. You also need to check the batteries. Just because you had them on charge, it does not mean they are fully charged or in good condition.
