Binding drive wheels.
Posted: Sun Feb 28, 2010 5:00 pm
Anyone else noticed the drive wheels binding when the retaining screw is tightened down ?
There appears to be about a 1mm gap between the the centre of the outer bearing and the end of the axle. Unfortunately the bearings are bonded to the wheels but I've looked from the reverse side and I can't see any gap between the bearing and the wheel.
The wheels do rotate but this extra friction will have a detrimental effect on power consumption and hence battery life.
Posted: Mon Mar 01, 2010 7:23 am
by Derek Attree
Hi Adrian
I have the same on some of my wheels
I have not as yet looked at why they are binding but I have the same gap.
I am sure there will be a simple fix.
Posted: Mon Mar 01, 2010 8:47 am
by Garry Coomber
I am assuming you mean the sprockets. I had the same problem, it is very fine between freely running and stiff or plain locked up.
What I did was to put the gear/drive shaft into the lathe and effectively polish the arge flat surface on the back of the piece. There was not need to use a tool in the lathe, just emery cloth. From memory just enough to polish out the machining marks was enough.
Posted: Mon Mar 01, 2010 9:58 am
by Derek Attree
Hi Gary
I mean the 6 pairs of wheels with tires. the Sprockets
were fine.
Posted: Mon Mar 01, 2010 3:04 pm
by Garry Coomber
Ah,
I don't remember that being a problem, but then it hasn't had a lot done to it for some time.
Posted: Tue Mar 02, 2010 10:47 am
by Dennis Jones
Adrian, I know this may sound silly, but I presume you haven't sprayed the mating surfaces ?
Dennis.
Posted: Tue Mar 02, 2010 2:28 pm
Unfortunately I bought this Pz III part built so the bearings were already in place but I don't think the wheels were sprayed beforehand.
The gap appears to be bigger than I would expect for a layer of paint.
Posted: Wed Mar 03, 2010 11:23 am
by Derek Attree
Adrian
My bearings have the same gap so I dont think it is problem from how things
went together.
I am looking at changing the cap or making up a small spacer washer.
When I get a chance to look I will post what I do.
by Derek Attree
Adrian
went together.
Posted: Tue Mar 09, 2010 9:52 pm
by Derek Attree
Hi Adrian
I have fitted an M4 washer between the end of the axel
and the end cap it has fixed the binding on my wheels.
Posted: Tue Mar 09, 2010 11:00 pm
Thanks Derek - sounds like an easy fix
