I am getting near the point of wanting to spray the lower hull.
I sprayed each component of the the lower hull separately (suspension arms. bump stops etc) with etching primer before assembly.
I intend to spray on some red oxide primer before putting on the top coats and was wondering whether I should remove the suspension arms and spray them separately or just spray them in place with the rest of the lower hull (with appropriate masking of the parts not requiring paint).
You can tell I am use to spraying static plastic models but not larger metal working models.
Any advice gratefully received.
Painting question
