I'm wondering about the indicated adhesive for the fender tread plates. Is low strength Loctite, as indicated in the instructions, correct? I was considering a good two part epoxy or perhaps a very tough contact cement because of possible flexing of the fenders.
Thanks.
Fender tread plate adhesive question.
- Has liked: 218 times
- Been liked: 180 times
Hi Lawrence
I did one section at a time and used loads of clamps.
I also used 60 grit Al oxide paper to get a good key on the fender and the back face of the brass.
Any glue that comes through the holes in the plates I removed with cotton buds and acetone.
You will get glue on you fingers a pair of gloves help its a bit messy !!.
