Update Tow Rope Eyes
clive Lockwood
Post by clive Lockwood »
Hi All,
I have made this master of the Towing eye, i have seen a few using it as well as the normal metal eye but i think this one is just a bit different and it,s the one i'm going to use on my own Panzer,
It requires a 630mm steel cable and can be glued in to the sleeve of the eye, if you fancy using this design i can cast these in white metal, just send me a PM.
colin fairweather
Been liked: 9 times
Post by colin fairweather »
nice one clive :D
keep them comeing
know get working on the smaller engine hatch
latches :wink: :D :D
regards
colin :D
2006 222 SOLD
2009 pzr111 046 SOLD
clive Lockwood
:lol: :lol: :lol:
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Post by Dennis Jones »
Hi Clive, Can you tell me please how you do the dummy welding.
clive Lockwood
Hi Dennis, I use a product called milliput, readily available and comes as a two part putty, so you mix equat parts rolling around in your hands untill mixed, then use masking tape either side of your weld area to contain the milliput and then it,s just a case of using a profiled tool to put the actual marks into the putty.
cheers.
clive
Dennis Jones
Has liked: 10 times
Clive, Thanks for that. Waiting to spray lower hull with primer but unfortunately garage is at about -2 degs at the moment and it's too big to heat up, I have a 12 X 12 workshop in the corner but too confined to spray.
