A PAIR OF SPEAKERS
Robin Ellis
Been liked: 8 times
A PAIR OF SPEAKERS
Post by Robin Ellis »
Can anyone recommend a pair of 4" speakers for use with Benedini sound system?
Has liked: 1024 times
Been liked: 2094 times
Robin. I've used Maplin 6 inch car speakers, £16.99 online. Work well. Regards. Stephen
martin payne
Post by martin payne »
Hi robin
may be try these car speakers sony xs-fl035 10cm 4 oms
3-way 10cm (4") coaxial speakers
3-way coaxial
140W peak power
30W rated power
HOP cone diaphragm
HDLD High Density Layered Diaphragm
Frequency response: 40Hz-26kHz
Sensitivity: 90dB
Sold in pairs
Grilles supplied.
£23.99
Derek Attree
Has liked: 218 times
Been liked: 182 times
Post by Derek Attree »
hi Robin
I was told by Mark that you should not use 2 speakers
with the new Armortek sound system.
See you Saturday.
Robin Ellis
Been liked: 8 times
A PAIR OF SPEAKERS
Derek, dont forget my Tiger has always had two speakers from Benedinis original Chinese amp five years ago to his present 40w version.
David Pengelly
Been liked: 2 times
Post by David Pengelly »
There are 2 speakers included in the new type option pack . This was to be seen in the tiger 1 hull at Bovington yesterday.
Was die Hölle das war
Yes, they're Tannoy 6 ohm, 85dB. Excellent. Stephen
Robin Ellis
Been liked: 8 times
A PAIR OF SPEAKERS
Thanks guys, managed to get a pair of sony 4" Speakers, and they work O.K.
Marcel de Groene
Post by Marcel de Groene »
Hello Guys,
Is the Benedini system supplied with the first Panther suitable to fit two speakers. I had my Benedini set replaced later on because there were problems and the replacement set got a cooler attached to it. If possible, how to connect since only one pair of wires comes out.
Stay on tracks
Been liked: 3435 times
Hi
What speakers you can or can not use depends upon the amplifier, not the sound unit. Mr. Benedini's original chinese amp, good, his later packaged amps very bad. Original Armortek amp (in black plastic box) bad, new Armortek sound module very good.
