Having some time now, I' ve decided to go on electronics about my 222...
I' m now on the bench and there is some problems....I have probably an old fuse box unit ( not the same as illustrated) so it let me in great troubles!!...So if someone can help me, I will be apreciate it so mutch!..
My fuse box unit have 11 leads in front of it, one unique led on the top and a red buttons on a side....
What is this red button? ( If it' s a button?!..)
What are the battery leads ?from right to left I have 2 possibility : the second pair or the 3rd? And , of course what is the right pair for the speed controler? My problem is the both pairs of leads ( speed controller and battery leads) could be inverted as there is the same terminals!...Can I plug what I wants where I wants without problems? Not sure....
Same problem with the switch unit!..I have 2 possibility to plug it with the fuse box : 4th or 5th pair of leads?
I have a 6 volts battery for the receiver supply and armortek tell on the book I need a 4.8 V, do you know if 6 V will works or not?
Is someone can explain in more detail how I can connect the receiver and the power supply for it? I think I have to plug something on the fuse box but what exactly?
Well that 's all my " hard" questions and hope somone can help me as I do not wants making a mistake at this stage!...
If you have some pictures, it will be nice also as this is more easy to understand...
Thank you in anticipation..
Yves
ps Congratulation Antony and Jeff for your works!..
