wheel detailing
Posted: Sat Dec 27, 2008 3:45 pm
by Jeffrey Goff
Posted: Sat Dec 27, 2008 5:16 pm
by Tim Bowman
Hi Jeff
Off to a great start on the 222 I see.
It's sort of strange (in a very good way) to see posts from you under the 222 and not under the 88 forum.
I look forward to seeing more as you progress.
Posted: Sat Dec 27, 2008 7:11 pm
by Robert E Morey
Great work Jeff, The detail looks a lot better on the hubs! Is that lathe turned auto body filler? Looks great!
Posted: Sat Dec 27, 2008 9:15 pm
by Jeffrey Goff
Hi Bob, no body filler, just made a tool and scraped them to shape, I had almost a carrier bag full of shavings, the 20mm central holes I cut with a flat wood boring drill, I am sure any engineer reading this has fainted, but that's the fun, working out how to do something,
regards
Jeff
Posted: Sat Dec 27, 2008 11:34 pm
by Allan Richards
I can see your off to a good start Jeff. I like the idea of using the flat wood boring drill. I guess its not good for much else now but I do the same. I finally painted my barrel clamp yesterday but the cold weather is back again now, which makes painting a bit difficult. I will try some shading and dry brushing tomorrow.
Posted: Sun Jan 04, 2009 7:25 pm
by Robert E Morey
Jeff,
This engineer isn't fainting at your idea of using a wood bit to make a hole, but I would be affraid of it ripping it out of your vice or support and flinging it against the wall!
Sometimes the best part of engineering is finding an add lib solution.
