Drive casing rubbing against sprocket wheel
Posted: Sun Apr 27, 2025 4:25 pm
Hi Guys
A noob here trying to build a tiger tank late version so please take pity.
The problem I have is that the drive casing is bang up against the sprocket wheel.
The shaft protrudes about 1mm from the taper lock bearing as shown in the photo.
Do I hammer the bearing in until it protrudes one mm on the other side or do I force the shaft back by
packing out the hub cap retaining screw.
all the best
all the best
