Road wheels spacing
Posted: Mon Mar 17, 2025 10:20 am
Hi trying to find out some information if this is normal or an issue.
It’s to do with the rear track ideal wheel,with both track tensioners set at the same angle ,the right ideal wheel sits on the outside of the rear wheel set,and the left one sits well inside the rear wheel set,I’ve checked everything out and it seems correct.
Cya Scott
Cya Scott
