For SALE Late Tiger 1
Posted: Tue Jan 07, 2025 11:56 am
by ColinBraithwaite
Late Tiger 1 (2021)
The tank has full motion packs which includes the turret recoil, turret rotation, machine gun animation via a pot on the transmitter also the commanders head is animated again via a pot on the transmitter. The tank has the sound option pack and single smoke pack installed.
The main gun and both machine guns have muzzle flash.
The tank will be supplied with the commander’s machine gun as shown in the pictures along with dummy shells used and unused these are stored in the box when not in use.
The Noco dual charger is included both batteries can be charged simultaneously (or individually) via the power panel at the rear of the tank left hand side. The power panel has a built-in battery voltage checker each battery can be checked separately the indicator is isolated when not required. The charge ports (XT60) are also isolated when not in use.
The front hatches allow access to the main isolator on the left looking at the front of the tank and a cable break plug and socket under the right-side hatch this allows the batteries to be completely isolated when the tank is stored.
The wooden support bogie that the tank is sat on is also included I made this so that when the tank is not being used the suspension is unloaded keeping the tension rods as good as new. This also makes moving the tank around easier. I have a lever and blocks which I use when removing the bogie these will also be included in the sale.
The original Armortek manuals will also be supplied.
I will if required include the Jumper T16 pro transmitter I use to control the tank however it is an older TX and I have had to replace some of the cables inside so would recommend replacing this with a modern minimum 10 channel TX. It would however allow you to operate the tank straight away until a replacement can be obtained.
I am looking for £5,500 or nearest offer. (current total price for an early Tiger 1 is £8000)
I live in north east Lincolnshire.
Re: For SALE Late Tiger 1
Posted: Fri Jan 17, 2025 1:54 pm
by ColinBraithwaite
Price reduced to £5000 however I am more than happy to consider a fair offer.
Posted: Fri Jan 17, 2025 2:52 pm
by Jan van der Velden
hi,
can i have your email address?
i know someone who is very interested and would like to take this over.
greetings,
Johannes
