Evening all, brand new to this subject, just bought a leopard 2kit and have embarked on a stiff learning curve ,but enjoying the experience so far. I am in the process of mounting the rear bin covers. Have identified the hinge a,item CV0670 but it appears that all the hinges are the same hand I.e. the pivot pin all face the same way. The pin mounting holes are countersunk on the pin entry side and the bore is reduced in diameter opposite this countersink such that the pin will not enter the reduced diameter.
As such all the pins face to the l/h side and will not line up with the fixed pivot pin. Should I drill through and use adhesive to position the pins or have the incorrect hinges been supplied, should 2 part numbers be applied to indicate opposite handed components, also require a spare. How do I go about this?
Eric Hornby
Leopard 2 toolbox hinges
- Has liked: 27 times
- Been liked: 5 times
