OPEN ON THE 6TH FEB 2025
2023 Jagpanther New Build Part 10/2
graham pipe
Has liked: 49 times
Been liked: 209 times
Post by graham pipe »
Hi all,
Just a quick update on what's been happening over the Christmas holiday period.
Santa was very kind this year (courtesy of Mother-in-Law) and left in my stocking an Armorpak 20 tonne jack kit. Just what I needed to finish off the JP - how did he know...
It's a fine little model in cast resin, finely cast brass and whitemetal fittings, copper rivets and hand formed brass carry handles.It went together very well and quite quickly. A little bit of fettling to remove resin mould flash, drilling deeper holes for the copper rivets and making new lifting handles from 2mm annealed copper wire to replace the kit supplied brass items which were slightly too wide.
The operational tiny brass butterfly clasp on the upper bracket is a joy to behold as are the '44 and 3 digit manufacturer code stampings on all the brass parts. So thanks to Dave Dibb at Armorpak and Mark Lawson for such a great addition to the model.
So, just need to degrease, prime and paint. The small flat brass piece screws onto the rear hull panel just above the round starter plate with tiny countersink head screws and supports the foot of the jack.
Included in the photos are some shots of the real thing plus a Panzer 4 jack. I came across these on a Normandy farm back in the 1990's where they'd been in use since 1944. The advent of modern hydraulic jacks saw them relegated to the back of a barn and, following the death of the finder, the next generation had no use for or interest in them. I managed to get them for scrap value which would never happen these days. Oh, if only one could go back in time armed with the knowledge of today...
The real thing I acquired from a Normandy farmer back in the 1990's. His family liberated it along with wheels from a knocked out Panther.  Fully working and just missing one lifting handle
View of the opposite side.  The thing is unbelievably heavy...
Also acquired a Pz 4 jack which is seen here alongside for size comparison
The unassembled kit
The unassembled kit
After a few hours with files, small drills and CA glu
Look at the fine detail and tiny stamp marks - brilliant!
The tiny butterfly turnbuckle is fully functional and must have been a pain to make!
