I simple but very effective way to control volume from your transmitter.
A small length of brush cutter fuel hose as a coupling between a servo and the volume pot.
Works a treat
Probably been done before but I haven’t seen it.
Volume control
- Has liked: 17 times
- Been liked: 74 times
- Has liked: 14 times
- Been liked: 323 times
Re: Volume control
Hi Marco, I am not familiar with Benedini system.Gian Marco Menozzi wrote: ↑Sun Jul 21, 2024 12:30 pmhi,
in the Benedini commands,
command 11 and 12 are to control the volume
Marco
Is that what Armortek use?
If so, how do I access the commands?
- Has liked: 1341 times
- Been liked: 1538 times
Re: Volume control
If you select Sound 11 via switch or encoder and keep triggering it, the volume will slowly decrease.
If you select Sound 12 via switch or encoder and keep triggering it, the volume will slowly increase.
Re: Volume control
HIAndrew Gaze wrote: ↑Mon Jul 22, 2024 11:47 amHi Marco, I am not familiar with Benedini system.Gian Marco Menozzi wrote: ↑Sun Jul 21, 2024 12:30 pmhi,
Marco
Yes, the sound card ArmorTek uses is Benedini,
Adrian Harris explained how to do the commands,
Marco
