Good evening to all.
I’m a new member here and a new owner of a beautiful Tiger 1
Early variant model. The radio set up is my question.
Taranis X9D is the radio Mode 1. Set up.
Right stick controls the throttle and steering.
Going forward, either only the right track moves and a little stick and not f I go slow, one track rotates clockwise and the left track rotates ccw.
Can someone help me if this is just a Tx set up pls.
Thanks.
Julio.
Taranis Radio on the tiger 1 set up. Throttle
- Has liked: 1418 times
- Been liked: 1593 times
Re: Taranis Radio on the tiger 1 set up. Throttle
If you press the Page button from the main screen, you should get to a screen which shows what the transmitter is outputting to each channel, which will show whether you have the programming set up correctly.
Thanks Adrian.
So, Taranis x9D can be able to program fwd function with both tracks moving same direction and vice versa with reverse?
Right now, when I push the stick forward, right track only moves thus causing the tank to steer.
Thank you Adrian for your reply.
Julio
Julio
- Has liked: 753 times
- Been liked: 1772 times
Hi Julio
There are some useful screenshots of the Taranis settings I have for my Tiger when I recently had a programming problem. They may help you understand the transmitter settings or at least get you started in the right direction. It is important to get the Input settings correct first, then do the mixes.
viewtopic.php?p=99739#p99739
Gary
Gary
Good Morning Gary,
Thank you very much.
I will check the link you provided.
Thanks again….
Julio.
Thanks again….
Julio.
