Hi guys, stated making up my tracks links. The centre link has a treaded hole. I assume this is simply a dummy screw that needs to be fitted. Can’t see anything in the manual.
Cheers Martin.
81 track links
- Has liked: 38 times
- Been liked: 100 times
- Chang
- Has liked: 16023 times
- Been liked: 452 times
Re: 81 track links
Does it help?
Re: 81 track links
Thanks, I will check my fasteners bag, not sure I have that many hex bolts. This is what my manual says.
- Peter Quambusch
- Been liked: 995 times
Re: 81 track links
Hi Martin,
The read thing would have hex all around: Enjoy your build and pls post some more pics.
Peter
Peter
Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change A bunch of Tiger and Panther variants, Leo II, Famo, 222s, a few 88`s and smaler ones like Hetzer, Stug III, 251, etc.
- Been liked: 48 times
Re: 81 track links
Hi Martin, if you look at the video of the fully built Leopard when it gets to the front of the tank there is definitely a hex bolt in the middle fixing of the track.
From the number of M3 x 6mm fixings for the track I would expect that there would be around 170 M3 x 6mm hex bolts (or something similar) for this position in the tracks but there is no such item in the fixing list.
I am nowhere near as far ahead as you are in building my Leopard, so thank you for finding the little glitches in the design be5I get there.
I have always looked at these construction kits as second generation prototypes, so one should expect little hiccups hear and there.
David.
David.
- Been liked: 47 times
Re: 81 track links
The center connector seems to be split into upper and lower halves on the actual tank; that bolt is probably used to keep the halves clamped onto the track pins and help keep them from wandering off.
On the Armortek kit, since the center connector is a single piece, the threaded hole does not really serve any mechanical function and could be used for attacking a cosmetic hex head.
Aaron
Aaron
Re: 81 track links
Hi the centre link has two holes in it with a centre drilled hole and taped thread. It doesn’t look like it does anything physical and is only there for detail. Thanks Martin.
- Chang
Re: 81 track links
Martin Donnison wrote: ↑Mon Apr 01, 2024 12:51 pmHi the centre link ..... with a centre drilled hole and taped thread.
Also please read Aaron Cheng's words :
