Mr Dawe's Centurion.
Has liked: 2259 times
Been liked: 7149 times
Re: Mr Dawe's Centurion.
Testing, it's taken me 1\2 an hour to get this loaded! I can't write anything interesting as I keep getting logged out!
Last edited by Phil Woollard on Thu Feb 10, 2022 6:55 pm, edited 5 times in total.
Been liked: 3379 times
Phil, sorry for your problems but as per our email from yesterday, the issue is not on our end.
As you indicated, your old tablet works fine with our site, but your new one does not -that indicates a configuration error or setting on your new machine and not with our forum.
Kian
It's driving me crazy and it's getting worse!
Derek Attree
Has liked: 218 times
Been liked: 178 times
Post by Derek Attree »
Hi Phil
I am having the same problem on my Samsung phone accessing the site.
Its since the rebuild after the site was down a couple of weeks back, it works fine on my desk top and Macbook.
I cleared cookies and cashe made no difference.
hi Derek.
I've tried everything, I would imagine that the site security is a lot tighter now I could be wrong, I have no issues with any other site.
I'm so glad I kept this older device as its seems to work just fine!
Back to my old device with a crappy camera. So that's two of the six suspension units finshed, just the other four to detail now and they have the dampers..
The bump stop plates made and fitted.
Thats the rubber you sent me Phil.
Working rubber bump stops.
Done!
Done!
More of the same and even more to come for now but the boss likes to see the progress
Now onto the four suspension units that have the dampers
Lots of detail to add to these.
The dampers for the suspension units..
Dont know why this arm was at this angle
This arm had been bent out of shape so needed some work, a new angle was required on this piece anyway
Lots of material to remove here.
Extension pieces for the pivot shafts
Pivot shaft detail
Pivot shaft detail
Plunge cutting the compound angle for the oil fillers, you shouldn't really use an end mill for this but these have overlapping flutes so it removed the material just fine.
Checking the final drive has clearance.
One half done.
One half done.
And now to the other end which has a slightly different oil filler position to also include an access cover.
I can't load photos now, it's worse than ever!
For Phil.
Derek Attree
Hi Phil
Loving what you are doing to this model.
Keep up the good work.
Phil Dawe
Has liked: 754 times
Been liked: 276 times
Post by Phil Dawe »
I thought the storm would have kept you out of the workshop Phil! I see what you mean about the coil springs!
The storm kept me out the workshop Phil as we had power outs over three days! Back in there now.
Moving on with the suspension units, the more I research the more detail I find .
I don't have the luxury of cnc but I do have Phil N C .
The only way to get the stub axles out is with some heat.
Carefully following the lines with the x and y axis.
For those that are interested.
We had no plans to take the hull down to this extent but needs must to get a good finish.
With a bit of elbow grease and all is smooth ready for the armour plate stippling effect.
Weld worms
Weld worms
Smooth as a babies arse.
More detail than this?
And now to the nr side.
My afternoon box.
My afternoon box.
Phil Dawe
Post by Phil Dawe »
Loving it all Phil! Did you have problems with paint runs in the original sand colour paint that required a lot of rubbing back? A bit more space in the workshop now the Rolls Royce AC has finally arrived here!
