Stug III 2020 57
Björn Johansson
Has liked: 481 times
Been liked: 408 times
Re: Stug III 2020 57
Post by Björn Johansson »
Some small update , at last it was a progress in the weather over here .
So I could do some paint job , start with the road wheels.
Some more paint :wink:
At last some fun stuff :D
Kind regards from Björn
Björn Johansson
Got all the tyres on , last time one did as many most have been for a RC Car competion in mid 90`s :P
Also try to do some simple dust cover on the inside bearings , not sure off the outcome though :|
Have a good weekend
Has liked: 1490 times
Been liked: 1695 times
I don't think I've ever seen that done before 8)
Has liked: 161 times
Been liked: 849 times
That's clever use of common parts! Better stock up on Pepsi!
Björn Johansson
:D Nice to be able to contribute with something new .
So ev I did go for a little leather gaiter
Björn Johansson
So at last I got the "Inspection hatch " done , read that it should be for the fanbelt but not sure :?
:D :D " you can see that I first had it on wrong side , flipping the chassi up side down" Lucky I only got to do two hole before I realized :D :D
Björn Johansson
Work off the day was to come up with something to replace those forward/rear end bump stop.
Took some cover plug , that original was for cars ,etc
Some detail painting to be done
then it was time for those air intake and frame to be mounted
Björn Johansson
Work off the day , :)
Now I will take a break for a couple off days :)
Björn Johansson
Couldn´t resist when opportunity came up.
140 1,6mm hole and 140 1,6 rivet screw with loctite later, the fenders are about ready to go to paint. :P
Last edited by Björn Johansson on Mon May 23, 2022 7:23 pm, edited 1 time in total.
Love all the details but I would worry the tracks might snag on those fasteners, especially the ones for the brackets :?:
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
I did the same to mine and have no problems running the Stug
I even used small fasteners to my rivets and they came threaded
cheers
Steen
Thanks Steen.
I haven't run a Stug or Panzer III but have had problems with the tracks catching when things have been bolted through the sponsons on Shermans.
Björn Johansson
Thank for advice Adrian , and Steen for you´r opinion grateful .
I perhaps did go to far with those 2/56 lock nuts, thougth they come handy :?
Will take a close look at it , when breaking in the motor´s and tracks .
Björn Johansson
A very small update on the 57
June went away like a rocket , with some helping on the family and a trip to Alsace and Munster 8)
Mostly paint work here and some adjustment to the fenders .
Some dummy bolts on the L-brackets
Motors are in and some off the electronics ,thanks to Robert for the help with channel mixing and set up with the radio.
Now we can break in gearboxes and ev do some test with the tracks on.
Björn Johansson
Some update on the 57th Stug.
Just when you got a cuple more 0-80 thread to do :(
Got this ideá some great time ago , with a frame , padding and some fake leather
Some stitch to it ,
Mostly paint work otherwise , but I could try the slew servo today
