Page 7 of 8
Re: Dales mid tiger 1
Posted: Wed Apr 10, 2013 7:27 am
by Dale jordan
Posted: Wed Apr 10, 2013 10:00 am
by phil fitzpatrick
Hi Dale,
Looks very good and you chose what I think is the hard end to do first
Posted: Wed Apr 10, 2013 4:18 pm
by simon_manning
looking good dale, i have the dreaded zim also in the next few months, keep the progress coming, regards simon.
Posted: Wed Apr 10, 2013 5:01 pm
by Tim Bowman
Hi Dale
Looks great! As Phil said, the mantle is one of the trickier part to zimmerit. At least you got that behind you.
The rest will be easy.
It was nice to here from you yesterday.
kindest regards
Posted: Thu Apr 11, 2013 6:55 am
by Dale jordan
The turret Zim done today . Dale
Posted: Thu Apr 11, 2013 10:59 am
by sam alayan
Dale jordan wrote:The turret Zim done today . Dale
its looking good dale
Posted: Fri Apr 12, 2013 11:38 pm
by Dale jordan
Nearly done , added the track tow rope cable onto the side then finished off the running gear . Next Zim the rear plate and refit all the hardware ...Dale
Posted: Sat Apr 13, 2013 7:03 am
by Simon Peck
Hi Dale.
Your Tiger is looking really nice. What are you using for the zimmerite, and how are you applying it? Is it still going to be from the 507?
Simon.
Posted: Sat Apr 13, 2013 7:11 am
by Dale jordan
Hello Simon click on the link below I did the same as Tim .. Not sure witch tiger unit yet . Zim was not much fun until I got the hang of it . The good thing if you don't like it just wash it off with water and go again . Dale
http://www.armortek.co.uk/Forum3b/viewt ... &start=195
Posted: Sat Apr 13, 2013 11:03 am
Nice work with the Zimm Dale.
I take it the paint will protect in once you're happy with it ?
Or is it like acrylic paint which is waterproof once fully dried ?
Posted: Sat Apr 13, 2013 10:37 pm
by Dale jordan
Hello Adrian , you have about 1/2 hour to play with it . If your not happy wash it off and start again it take all day to dry very good stuff sticks like glue a light sand then just prime it ..Dale
Posted: Sat Apr 13, 2013 11:00 pm
by Dale jordan
Up early today 6am in the shed did the rear plate .Dale
Posted: Sat Apr 13, 2013 11:40 pm
by Andrea Daviero
Hi Dale, great work with zimmerit, it seems perfect.
Only one thing:
In all pictures I've seen it seems that there is no zimmerit between the rear mudguard hinges and the bottom (so the area below the mudguards), I made the same mistake on my tiger, I will fix as soon I will repaint it.
Also, some tigers (not all) had zimmerit also on glacis, not a standard at all but there are pictures about them.
Posted: Sun Apr 14, 2013 10:34 pm
by Dale jordan
Thanks Andrew I removed the Zim from under the rear mud guards as it did not let them sit down properly well spot on that one ..Dale
Posted: Mon Apr 15, 2013 4:15 am
by Tim Bowman
Hi Dale
I did the same thing.
Easy to remove.
Xacto the edges where you want to remove to and simply, lightly chisel off with a flat head driver.
