OPEN ON THE 6TH FEB 2025
Has liked: 776 times
Been liked: 1743 times
Just out of curiosity, is the body of breech solid or is it hollow?
Has liked: 2267 times
Been liked: 7152 times
I agree, I'll file the breech block, or attempt to as this pla is a bit tricky to dress but I will have a go! I may still print another breech standing up as this would make the breech block sliding grooves more accurate, I hope?
The body of the breech is printed at 20% infill.
Another busy day, printing, painting and cabinet making, oh and wiring leds . 8)
I really need a good photo or drawing of the clansman twin radio installation, if anyone could share I would be so grateful.
It's getting very busy in there and there's lots still to make and install.
I have cut 12mm off the bottom of the breech to get it to look more correct, the turret basket is around 20mm to high so we have to compromise somewhere.
I do like lots of leds to show case the interior, the turret had around 5 bulkhead lamps, so we will have the same.
The stand alone led controller.
There's plenty of available amps in the led switcher, 20amps in fact , so one channel is now running the NBC  inlet fan.
Are you going to have a disco in there? :D :D
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Your going to be even busier if I shop tomorrow and drop the latest batch of parcels off at the PO.
Dave
www.armorpax.net
There's so much to do its unreal, working inside that turret it's like operating on a turtle, half the time your hands and fingers are in there and you just can't see what you are doing. That's why I make up sub units and fix them one at a time, should look ok when it's done though. Vince that breech is going to be awesome.
My 3d printer is working around 18hrs a day right now.
Dave I'm looking forward to receiving those parts, especially the cannon plugs so I can terminate the braided cables neatly.
Printing set up , So I can now get to the workshop busy busy. 8) just ordered the loader figure from ebay.
Vince can you send me this stl file please and I will play with the size.
Charge bag container v1.jpg (21.79 KiB) Viewed 441 times
That's another 2 more red leds required.
Vince do you fancy a stab at this. It's really just <br />4 cylinders! I can add all the detail?
Screenshot 2020-04-14 at 20.08.17 (1).jpg (92.46 KiB) Viewed 450 times
Short hesh rnds for the turret stowage racks.
The clansman radio sets x2 and x1 spare.
Stl file sent.
In that gun cradle diagram, what's the internal diameter and length of item no.8?
If we stick with my 40.90mm abs stock pipe, the cradle tube will need to slide over that, so maybe 2mm over size to allow for shrinkage and bonding? It's so exciting! I'm almost through my first pla reel of material. 8)
The distance from the front of the breech face to the kit barrel face is 130mm, so the cradle shouldn't be any longer than that which would need to include the big recuperation clamp and the threads and nuts associated with that :D
So that sleeve would be 43mm ID, about 47mm OD and 130mm long?
Two large hydraulic cylinders and two smaller hydraulic cylinders at the bottom?
Sounds about right for diameter, we need to factor in the large clamp at the breech front which bolts to the recuperation cylinders, and the clearance for the threads and nuts which protrude out from the cradle, just use your excellent judgment on that! So that 130mm is the total space available.
The two large cylinders are diagonally opposite each other, see photo.
There's the coax machine gun in place in this photo!
11439073826_805d5a9a54_b (2).jpg (118.17 KiB) Viewed 423 times
This is a good example.
iCnrk93 (2)_kindlephoto-10442907.jpg (30.99 KiB) Viewed 424 times
Do you have this clamp??
No I don't have the clamp, it's this big bugger at the breech front, it could be made part of the cradle of printed separately? Separately would be best if we want a recoiling moving breech. 8)
iCnrk93 (2).jpg (59.06 KiB) Viewed 412 times
I know what you are trying to do but have no idea how you are going to do it (call me a bit thick). Also I cannot visualise the limited space this has got to fit in. So what I will try to do is try to draw the major components individually and you will assemble them together. Maybe this will give you a chance of adjusting some dimensions as you go along.
The big clamp finished.
Some more components. Some I might have drawn longer so that you can adjust length. I have not drawn the cylinder rams. Best to use a metal or plasticard round bar cut to the required length.
Front liner
Front liner
Buffer cylinder
Buffer cylinder
Buffer cylinder bracket Short
Buffer cylinder bracket long
Replenisher
Replenisher
