OPEN ON THE 6TH FEB 2025
Online
Has liked: 2267 times
Been liked: 7152 times
The 3d printer arrived, I've put it together calibrated it all and it's now busy printing an owl!
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
You really don’t hang around...... :D
Mark Heaps
Has liked: 270 times
Been liked: 324 times
Post by Mark Heaps »
Make a rotary base junction for that floor and you will be able to rotate the turret 13 times clockwise before the turret unscrews and falls off.
Been liked: 1800 times
You'll have to tell us how Hedwig turned out :lol:
Online
It was so exciting, I thought it was going to be one big owl but it turned out that wasn't two clawed feet it was two different bodies!
Sorry I don't know how that one slipped in!
Setting out the turret cabinets and the commanders seat which I'm having real trouble with, simply from the lack of a plan view of just where it all fits in.
Once I have the printed shell x 20 I can start making the ammunition racks.
And now to attempt to print the 120mm shell file from Vince!
Kevin Hunter
Back to turret interior, you may have to invest a tenner but these may be useful?
https://www.greenmachinesurplus.com/chi ... -666-p.asp
Unless anyone already has them and prepared to share with you.....
Best
Kevin
Online
Thanks again Kevin, I have used these guys before! I have the drawings on the way.
Kind regards Phil
Online
Vince, your shell lives mate! 8)
Has liked: 776 times
Been liked: 1743 times
You made my day Phil. Good to hear that you were able to 3D print from my stl file. So what do you think? Does it look like a scaled down version of the real thing?
With the large area of your 3D printer you could print more than one shell at a time.
Online
I've not cleaned it up yet. There's quite a bit of scaffolding to remove but that's no big deal and the quality is excellent. I wonder if it would print ok stood up on its nose maybe?
I think you should be proud of that shell Vince!
I'm still learning to operate the machine and getting used to the Cura software that we have downloaded to run the file, it's all very promising indeed.
I will try to print say six shells at once, I will send you one as a thank you, just need your address by pm.
We have downloaded a scanning app that simply (simply my arse) uses your smart phone to basically take a guided video of the subject on a grid on a turntable, should be interesting if it works ok, it did have good reviews. So that's the next step, scanning! 8)
Has liked: 132 times
Been liked: 783 times
Phil trying printing vertically. Should be ok, no overhangs to speak of. Perhaps less woodgrain effect.
Online
Hi Bob, we are working on the editing of the stl file program as we speak, we need to change the axis so we can print any which way with minimal cleaning up, I don't want to lose the tracer holes either as some of the rounds are stored nose down in the turret racking.
I've been printing shells since dawn this morning ( this machine has to pay for its self asap), do you know the machine even tells you the individual manufacturing cost of each unit, less you time of course!
I'm now about to start cleaning up the shells in the workshop, paint them and see just how good the quality is. 8)
I also need to make a couple of the electrical cabinets today so I can replicate those as there are so many.
Scanning an object is my next steep learning curve. 8)
Kevin Hunter
Morning Phil, what scanning app are you planning to use?
Kevin
Btw, did that email stuff arrive ok?
Online
Morning Kevin, Qlone. Can't comment on it yet though. Yes the email drawings came through just fine, many thanks. 8)
Online
A very busy day, cleaned up the shells, and have been working on the commanders seat and foot well. 8)
The led controller, this is a independent device so that the interior lights can be remotely switched.
The up and downy seat mech. Space is very tight in the compromised turret . See how close the turret turn gear is to the internal fittings, I'm constantly checking that everything misses this important part.
The 120mm hesh shells have cleaned up nicely, the pla filament is very tough indeed and is a bugger to work, you need many coats of filler primer!
