The life and times of No 28.
Forum for discussion relating to the 1948 - 1950 Series 1 4x4 car
Charles A Stewart
Has liked: 512 times
Been liked: 933 times
Re: The life and times of No 28.
Post by Charles A Stewart »
Good evening everybody.
A small update, painted the bonnet!!
WOW: So what you say. I don't blame you, small steps, fitting in with everything else and I still haven't painted my shed yet. Anyway a picture speaks a thousand whatsits:-
The gentleman now has the appropriate accouterments for a potential S1 owner (mug of tea, essential. Pipe, optional)
I will varnish/lacquer the bonnet and store it safely until the rest catches up and I can actually present a complete model on this forum in the not to distant future(this year).
Have a good weekend.
Charles
PS The weathering on the tyres and wheels, is real soil/earth, not paint 8) :-D
Been liked: 1842 times
Number one fan here. Nice to see so much detail on the Bonnet/Hood, "fake dust not rust" the order of the day :lol:
After all the panels are alloy weren't/aren't they?
Ok, apparently not on the model. :lol:
Ps love the light mud on the tyres and wheels.
Charles A Stewart
Good evening folks.
I have had to wait awhile for the headlight lenses to arrive, so was able to spend the afternoon pottering with the LED's and the wiring. Also catching up with the "TankFest" stream too.
Lenses tacked in place.
I have used watch lenses fitted over the light to get that rounded effect of the headlamp, I haven't scored them yet.
.... and someone said "let there be light"
Please note, If you are going down the road I am, you will require a larger badge to fix the grill on. nudge nudge wink wink 8)
As always take care and have fun.
Charles
Nice, 1940's warm white.
"And let there be light" and God sent forward an electrician.
:lol:
Charles A Stewart
Thank you John.
Knew someone would make the connection :D :D
Robert Reid
Has liked: 99 times
Been liked: 446 times
Post by Robert Reid »
Your wheels/tires are superb!
RPR
Charles A Stewart
Hi folks.
Thank you Robert for your feed back, a couple of runs around my tank track is all it took, real weathering, where have I heard that recently?
Last week I spent some time(two days) cleaning/pimping a real 110 .... ....., for my sons school prom. It did look good though, but can't for obvious reasons post a photo here.
Anyway the grateful chap that my son is, bought this for me.
Shall be worn, if I ever get together with the like minded.
Take care all.
Charles
Charles A Stewart
Hi Folks.
A little more fiddly progress with No. 28.
The first fiddly bit was the Steering wheel bracket, which involves folding, bending and trigonometry(which isn't ain't my strongest asset). To save space here I won't include a photo of a pile of shaped cardboard or bits of odd looking Ali.
I'll just show the result:-
Still a bit of cleaning up to do, seems to work though.
There is a slight upward angle on the top, but I can live with that. The clamp for the steering column also needs finalizing too
The other side, obviously.
Another small concern I had, has hopefully been addressed, i.e "how do you fix the bigger headlights to the front of the S1?"
Glue a bracket behind and screw the headlight on. This should clamp the lens in place.
So there you go, that's it for now.
Take care.
Charles
Charles A Stewart
Hi Folks.
I hope all is well with everyone.
Small update, still tweaking this and that, I do love the BA system of nuts and bolts, being able for example to get a 10BA thread with a 12BA head thus a smaller profile bolt head for a stronger thread. I freely admit when I first got involved with this addictive 1/6 armour (armor,USA) stuff , it was bewildering to say the least.
Working around the cab of the S! I am using the above mentioned fastenings, more of that later.
Today's experiment, which I hope bears fruit, despite a broken drill bit in the most inconvenient place possible, right at the end of the hole :roll:
That's life, still here we are:-
True these are too bright, but its going work better with 6v rather than 3v which these are rate at.
Actually doesn't look too bad as is, top light needs to be orange/amber: I believe.
The holes in the battery case, for those wondering, are for a more prototypical seat fastening that doesn't involve Velcro. Curious?
Take care all.
Charles
Charles A Stewart
Good evening all.
For a while now I have been scratching my head on how to bend the kit supplied stiff brass capping for the cargo 'tub'. I have several hammers, a decent vice etc.
Before bashing out/wrecking the kit provided brass capping I thought to copy them and see how it works: It didn't :oops: :roll:
Therefore, plan something (from the alphabet, E,G or J).
Plan K:- break it down :-D !
Here we go:-
Use  original as a template and thinner brass. Other materials available too.
Carefully super glue/loctite parts in place.
I hope a bit of trimming will suffice once glue in place.
To finish, some cleaning up, attach rivets sort the holes for canopy posts and maybe add one or two extra bits, e.g just above the door handle slot, we'll see.
Take care.
Charles
Charles A Stewart
Evening all.
Today we were mainly doing electrics. Specifically testing the front end.
A word of caution first, I bought an extra couple of R/C switchers, same type as the one supplied with the motion kit. when I plugged it in the lights would light up dimly, not off, then go full on when switched on, odd. :shock: :-?
Used the other one and everything is wonderful :-
OK, sorry about the spaghetti :) But it works!!!
Being a slightly later(1950+) S1, we get to have bigger head lamps :D
Didn't expect it this bright, at least the cats can see the S1 coming.
And I will hang the washing up too :oops: Now I can see it.
Keep up the fun.
Charles
Good to see your making light work of it all Charles. :lol:
Like the bendy thingy, I borrow a mate's when I need one coz I'm tight! :oops:
Charles A Stewart
Re: Riveting stuff
Hi Folks.
Hope all is well with everybody.
Little update, took a while, but being confined to barracks by the recent weather, my eyeballs are now knackered, :shock:. However, the tub is almost ready for a coat of paint.
Loads and loads of little plastic rivets.
More riveting.
More riveting.
In the end I didn't use the AT brass capping, my bending skills and equipment are a bit limited and the brass is quite thick. They are however very good as templates with to which mark out and cut from thinner brass sheets. As a future project I will make up the individual(which they are in the first place) capping parts.
That's all for now folks.
Charles
PS Them handles are getting replaced, more my level of bending things :lol:
Riveting :lol:
Charles A Stewart
Hi folks.
All's well with all I hope.
Been busy painting as the weather was, for a change, helpful. There is still work to do, but as we are at this stage we will fit the electric bits and do a bit of running around and see what parts stay where they should, or not.
Overview
Overview
I am adding the rear lights shortly. I know someone who might recognize these cans.
Hoops added
Hoops added
Take care.
Charles
