Dale easy eight No 65
- Been liked: 429 times
- Has liked: 127 times
- Been liked: 758 times
Re: Dale easy eight No 65
Quick question are the 8mm pins for the suspension pivots stainless steel ? Dale
Dale
I don't think so, I think they are carbon (ie non-stainless) steel. I replaced mine with 316SS to prevent rust.
- Has liked: 75 times
- Been liked: 26 times
I’m not sure whether it’s stainless. I exchanged mine for a brass tube. I put a thread in the tubes so I can remove them if necessary.
Building Sherman Easy Eight
Leopard 2A4 ordered
Leopard 2A4 ordered
Really happy with the look of the casting detail on the suspension arms I filled the webbing holes from the back . Dale
Lower hull painted Olive Drab . Test fitting bogie number one I used loctite 480 for the first time boy its strong I had one tyre on crooked had all types of trouble getting it off . I hat to use a razor knife to get under the rubber , lucky only one to do . Dale
Following Daves lead again . I did raise the position of the MG port and over a bit as well . Dale
Put a lot of work into the side hatch today plus made new lifting hooks to the correct size and repositioned them . . Dale
