Page 6 of 14
Re: New member panther g 1944
Posted: Fri Dec 30, 2022 6:04 pm
by Malcolm.Plumb
That is so close,you definitely have to use a low profile bolt.
Posted: Fri Dec 30, 2022 6:12 pm
by Gary Rafferty
Hi All
Finally finished matching all the bushings to the various suspension parts.
Took far longer than I thought it would :lol:
Gary
Posted: Fri Dec 30, 2022 6:14 pm
by Gary Rafferty
Hi Malcolm
The bolt is 2.5x6mm I don't think you could get much smaller that will bolt through the sprocket unfortunately.
However I'm still looking :D
Gary
Posted: Fri Dec 30, 2022 7:23 pm
by Vince Cutajar
Gary
I've seen 2.5mm bolts as short as 3mm (2.5x3).
One can grind the head of the bolt to make it low profile but I would still worry that the track horns might still hit them.
Or one can counterbore to hide the head of the bolt although it's easier said than done.
Posted: Fri Dec 30, 2022 8:27 pm
by Gary Rafferty
Gary
Hi Vince
I like the counterbore idea it will require the head of the bolt to be almost flush with the back of the sprocket, certainly something to look into.
Gary
Posted: Sat Dec 31, 2022 9:08 am
by William Gardeniers
Hello counterbore is the way too go then you have no problem with the Tracks.
Posted: Sat Dec 31, 2022 10:53 am
by Gary Rafferty
Hi William
Thanks for the imput regarding the sprocket bolts.
I have to say that sprocket with texture and sprocket casting number is outstanding.
Gary
Posted: Sat Dec 31, 2022 12:46 pm
by Gary Rafferty
Hi All
So time to start building the hull :D
Unfortunately hoping to use the new movable bench
To start work on then the misses decides she wants to get fit and use her rollers just where I need to work :lol:
So will have to carry on with using my workshop bench for the moment..
Probably part of the build most concerned about.
Finally feel like I'm getting somewhere :D
Gary
Posted: Sat Dec 31, 2022 1:13 pm
by Vince Cutajar
Gary
Here is a link for short 2.5mm bolts:
https://www.westfieldfasteners.co.uk/A2 ... Rfull.html
Posted: Sat Dec 31, 2022 1:37 pm
by Gary Rafferty
Gary
Hi Vince
Superb thanks very much for the link.
Gary
Posted: Sat Dec 31, 2022 1:41 pm
by Gary Rafferty
Hi All
Last post of the day.
Everything matched and numbered will loctite all bushes and swing arms and hopefully carry on tomorrow.
Happy new year to everyone
Gary
Posted: Sat Dec 31, 2022 5:13 pm
by Malcolm.Plumb
Progressing well and looking very nice Gary.
At what stage are you planning to get some primer laid down and some painting done?
Posted: Sat Dec 31, 2022 5:57 pm
by Gary Rafferty
Hi Malcolm
Thanks for the continued support, basically I have dry fitted everything to make sure it fits.
So by next weekend I should be good to go on the paint front.
I just need to make a few adjustments to my workshop for painting.
Upol degreaser, 6x upol etch primer grey 4x red halfords primer 6 x ral dunkelgelb so should have enough for painting the tank for finalfinishing, tank will then go to my painter.
Gary
Posted: Sat Jan 07, 2023 2:39 pm
by Gary Rafferty
Hi All
Hopefully everyone had a cracking Christmas and New year.
So finished loctiting suspension arm's unfortunately one of them didn't take moved when I tested it...
I left it 5 days for loctite to go off, unfortunately it's knackered the thread in the suspension arm and torsion bar holder :cry:
I have ordered a tap and die set to see if I can recover it..
Masking up for painting just trying etch primer on a piece of scrap aluminium.
Gary
Posted: Sat Jan 07, 2023 4:55 pm
by graham pipe
Hi Gary,
Looks like you're making good progress. Not wishing to teach you how to suck eggs (!) but don't forget to thoroughly degrease everything prior to priming - even etch primer won't fight its way through fingerprints, etc! And if you can abrade the surface first that will give an even better bond. On my JP, I sand or glass bead blasted all parts before painting and, as an extra precaution, gave everything a good wipe down or swill off with acetone. Amazingly, here in France one can buy acetone off the shelf in all supermarkets!!
Look forward to more news of your build.
Regards from Normandy,
G
