Page 6 of 54
Re: Mr Dawe's Centurion.
Posted: Wed Feb 02, 2022 8:11 pm
by Phil Dawe
Superb Phil! Have you resolved your forum posting issues?
Posted: Wed Feb 02, 2022 8:18 pm
by Phil Woollard
Nope, it's still logging me out I just cross my fingers as I write and post the days events. To be fair it was not quite as bad this evening.
Posted: Thu Feb 03, 2022 6:06 pm
by Phil Woollard
The idlers are just about done all but for some 1.5mm bolts for the hub covers.
I'm still having problems with being logged out!
Posted: Thu Feb 03, 2022 6:46 pm
by simon_manning
Nice, regards simon.
Posted: Thu Feb 03, 2022 10:15 pm
by Stephen White
'Could anyone tell us when these numbers were used
Part numbers, relating to the Ilustrated Parts List and te manufacturer’s drawings. Some also indicate the foundry which cast the part. In this case, ROF W is Royal Ordnance Factory Woolwich.
They’re all over Centurion if you look hard enough.
Posted: Fri Feb 04, 2022 7:19 am
by Phil Woollard
As my question and road wheel photo suggests I was referring to the road wheel hub covers.
Posted: Fri Feb 04, 2022 7:40 am
by Stephen White
? That’s what I answered, Phil.
Posted: Fri Feb 04, 2022 11:11 am
by Phil Woollard
Thank you Stephen, maybe I shall add these road wheel hub id's to the odd one of two on each side unless the later mks didn't use them.
Posted: Fri Feb 04, 2022 5:48 pm
by Phil Woollard
This afternoons exploits.I'm still having trouble with getting locked out.
Posted: Fri Feb 04, 2022 9:38 pm
by Phil Dawe
Stephen White wrote: ↑Fri Feb 04, 2022 7:40 am
Stephen, I think Phil was asking could these hubs with part numbers cast in appear randomly on any Mark of Cent or was it particular to early or late marks.
Posted: Sat Feb 05, 2022 7:36 am
by Stephen White
Ah, you’re a mind reader.
The use of casting marks appears to vary between foundries. Supplies of parts to the production line would mix sources. The result is what appears to be random presence on completed vehicles. Parts might be further mixed during base overhaul/upgrading. So they would not be incorrect on any mark.
Posted: Mon Feb 07, 2022 6:02 pm
by Phil Woollard
The second machining stage of the suspension units is now complete.
Posted: Wed Feb 09, 2022 6:26 pm
by Phil Woollard
I'm having trouble loading the days work but will keep trying.
I am having to load photos on my new device, that device has a wonderful up to date camera, then edit and load the text for each photo on my old identical device or I get logged out...very strange.
Posted: Thu Feb 10, 2022 12:11 pm
by Phil Woollard
Testing, I've deleted all cookies, turned off my older device and checked the security settings but to no avail. I'm still getting logged out! It's just hit and miss. I had no problem before the site crashed. If I continuously have to log in even after clicking on " keep me logged in" is the problem my end?
Posted: Thu Feb 10, 2022 12:20 pm
by Kevin Hunter
Phil - thanks for persevering with your posts through the technical difficulties you are experiencing. I know I speak for others - your work is exceptional to watch, and it would be a real loss to the forum if you couldn’t/didn’t continue.
Kevin
