Hi All,
Two years in! Here is a summary...followers of the thread may wish to skip this post.
So where have I got to?
Still a few things to sort out before a full dismantle ready for priming. I need to sort out the toolbox frame, mark up holes for bolts to secure the front roof frame and possibly adjust the mounting for the rear reflector as the original holes are partially covered by the plates added to bring the lower side plates up to scale thickness.
What have I decided:
Steel top deck and turret roof secured by magnets
Beier sound system,
Homebrew smokers based on Benedini elements with MOSFET control via ItsyBitsy micro-computer,
Radiator fan animation using A4988 stepper motor controllers and Teensy3.2 micro computer.
24V power from two 12V 30Ah LiFePO4 in series. Power on/off and circuit split (for charging) using relays.
12V 12Ah LiFePO4 battery in chassis for sound, fan animation, smoker fans, bow MG animation and lights. This will be energised via a relay and have fusing for each service.
Electrically isolated turret with 12V electrics, via a relay and with fusing.
FrSky Horus X10 Express transmitter and Archer R10/R8 Pro receivers.
What am I working on (or playing with
Homebrew gear box for gun elevation based on robot parts with servo actuation so that rate and end stops can be programmed.
Replacing turret rotation motor with one that includes a rotary encoder so that slew angle can be commanded explicitly and avoid areas programmed as required.
What is still undecided:
What mechanical/electrical features from the 2021 Late Tiger 1 model to include: bow MG animation, revised final drive....?
Precise means of providing flash and smoke for main gun.
Animated commander figure.
So still much to do... and then there is the ‘accurizing’. For those following this thread you will have seen that for me the kit and aftermarket parts are excellent starting points most of which can be further enhanced.
Alastair
