Brian's 2017 NO. 10 LATE TIGER 1 BUILD
- Brian Ostlind
- Has liked: 972 times
- Been liked: 2068 times
- Brian Ostlind
SPROCKETS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Ok I temporarily assembled the back rings on the sprockets but I had to order longer screws because 8mm won’t let me thread on half the nuts and the other half are hanging on by one thread. I did glue some final drive gears into the bearings on the drive housings. I was etch priming some hubcaps but got impatient and didn’t let them dry all the way so the little indents on the flat hubcaps repelled the primer so they look a little uneven. That and I think I inhaled some primer, that stuff is nasty.
I am starting to regret painting some parts in primer before assembly because loctite really ruins the paint and makes a mess.
- Brian Ostlind
Re: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Did someone say that you can melt the glue with a blowtorch? Then Replace the bearings?
I never did put the oil seal the drive housings, so I could fix that.
When I glue the shaft in should I put the glue on the shaft or inside the bearings only. I did both the first time.
- Brian Ostlind
DRIVESHAFT: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Big job to take the shaft back out but I got them undone with the help of a blowtorch. I had put way too much glue on the shaft and it piled up inside the bearing. Just need to polish the parts and rebuild them.
- Has liked: 781 times
- Been liked: 1745 times
If it was just dragging a little I was going to suggest to leave them be, but it seems you have managed to take it apart safely.
- Brian Ostlind
ROADWHEELS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
I got some painting done! Just a small sample to check out my system. I was running a 1mm needle in the HVLP gun with a turbine compressor. Three coats later It looks ok but I am going to try a .8mm needle next time for thinner coats.
- Brian Ostlind
- Brian Ostlind
I haven’t painted any front sides but can do a mock up, and I am super excited to get the smaller needle and paint the rest of the wheels. I just picked up another gallon of this incredible paint.
- Brian Ostlind
I’m going to bake these in the sun for a little while then try sanding the paint down to get them fitting together and maybe ad tooth for matt varnish coat
- Has liked: 135 times
- Been liked: 795 times
Brian
The color looks great. Perhaps a little on the glossy side when wet. But after it dries it will be more matte (Flat)? Just curious - the outer facing side of the "H" shaped road wheels need the 6X metal tabs like your inner road wheels. Why paint the wheels without the tabs? Perhaps they are on the other side of wheel (away from viewer)?
My apologies to mark up your photo.
Last edited by Robert E Morey on Tue Jul 03, 2018 10:28 pm, edited 1 time in total.
- Brian Ostlind
Hi Bob, this photo is a mock up. I haven’t painted any front wheel faces yet, that’s why the one in the middle is silver. It’s my round about way of doing a small batch to get the painting started and not make any mistakes on parts that show. The paint is Highly glossy, that’s just the nature of the paint I am using. I have ordered a flat clear coat from Mission Model Paints and they said it will cover the wheels without a problem.
- Brian Ostlind
Here are the correctly assembled wheels on a little piece of track. I wanted to check the spacing out. The inner faces have been painted, the outer front faces are next. I did have to grind down the hubcaps because they shouldn’t have been painted yet I got carried away. But everything fits.
- Brian Ostlind
- Brian Ostlind
PRIMER: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Just doing some small parts with red primer inside today
- Brian Ostlind
