panther build.. at last!
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
stunning detail, and beautiful believable paintwork, this will be another work of art
regards Jeff
David Gray
Been liked: 1 time
Post by David Gray »
Brilliant Simon , the best weathering i have seen yet,
Dave Gray
Thanks Jeff and David, good to have some encouragement!
this is about where i am at the moment. this is a paint marathon, not to bad at 1/35 scale but at 1/6 theres lots to do. thanks per for the ir box posting. i will add the lifting hook! regards simon
yves mouton
Been liked: 741 times
weathering
Post by yves mouton »
Hi Simon,
Your weathering skills are beautiful, you are a master!
The mig pigments that you are using do you airbrush that on the tank?
regards Yves
this is the exhaust i've been working on , steve winstone made the tubeing and fans, i fiited it together and soldered the joints and cut to size, plenty more to do , theres a lot to these parts to get it to look right, the exhaust collars still need to be made and then the paint! thanks steve for the help. regards simon.
COOL! 8)
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Simon.
This build just gets better and better.
cant wait to see whats next.
thanks steve and tim, the exhausts are fitted, on to the next step? regards simon.
Has liked: 161 times
Been liked: 830 times
Simon,
Those are some really nice looking pipes! Wow fine job! I like how you rust pit the paint, it looks absolutely real.
Kind regards,
Jeffrey Goff
Has liked: 20 times
Hi Simon, more great work, the weld seams on the exhaust boxes are first class, and completely believable, keep the pictures coming
regards
Jeff
peter karlsson
Post by peter karlsson »
hi simon!!!
just say REALY OUTSTANDING WORK AS USUAL :!: :!:
kind regards peter(peppe)
David Gray
Been liked: 1 time
you,ve really got this weathering off to a T , love it
Dave Gray :D
i am starting the deck amongst other parts, working out the bolt patterns, turret clearance, thanks everyone who's posted, hope it gives something to look at. regards simon.
Antony Rowley
Location: Back to Wirral home of the brave or not so brave, England
Post by Antony Rowley »
Hi Simon,
Is this some sort of hybrid you're creating as I've noticed you've put some zim on the mudguard :?: An Ausf G with Chin definately has no zim :wink:
Also are you leaving the main body of your Panther in Oxide Red or are you going to paint the too :?:
One more question regarding your excellent exhaust fans, are they going to rotate when the smoker is switched on :?:
Thanks Antony
Kent Wiik
Has liked: 6 times
Been liked: 194 times
Post by Kent Wiik »
Antony Rowley wrote:One more question regarding your excellent exhaust fans, are they going to rotate when the smoker is switched on :?:
? :? Hmmm, to my knowledge the blades was fixed attached but you might have other information about this?
It´s all in the details!
