OPEN ON THE 6TH FEB 2025
Has liked: 776 times
Been liked: 1743 times
I will see what material diameters I have after all. Hope you are not in a mad rush.
Has liked: 2267 times
Been liked: 7152 times
No rush at all Vince by the end of the week will be just fine! I have the interior to sort so no worries, just very pleased you may be able to do it! Thank Vince and stay safe.
Kevin Hunter
Has liked: 598 times
Been liked: 145 times
Post by Kevin Hunter »
Phil Woollard wrote:
Mon Mar 30, 2020 7:42 pm
The Driving band can then be added later
A 20mm compression olive would probably be just the job?
Hi Phil
You're quite today.
Haven't been to the workshop to check on what material I have yet. Daughter came from the UK as university labs have closed down and so at the moment in mandatory self-isolation till Wednesday.
Passed the time making a 3D drawing instead.
Does it look OK? I am wondering if it can be 3D printed. I don't have a 3D printer but if anybody wants to give it a go I can send the .stl file.
I've been bent over the chieftain all day Vince, that looks awesome. Shame I don't have a 3d printer, anyone fancy a go? I've just had a look on eBay and the printers are not much dosh, £150 gets you started and it looks like it would print the shells ok. Only problem is driving the dam thing ! :roll:
I have finally found a pic of the troublesome metadyne compartment, now as the turret roof will be removable I better attempt the birds nest!
I'm using 3 mm abs for this work and it's like using aluminium!
The nearly finished batteries before weathering.
That's Velcro on the base to hold them in there but will allow me to remove them for painting
The water containers are there to.
A little secret, those battery terminal clamps and wires are actually hearing aid parts!
Last edited by Phil Woollard on Tue Mar 31, 2020 5:13 pm, edited 2 times in total.
Kevin Hunter
Just amazing.......
Has liked: 1024 times
Been liked: 2094 times
Great details Phil. Vince, you might find these helpful, they're from Rob Griffin's book, for reference.
Your HESH round model looks great. Note that on the base, there should be four circular recesses, which are the vents for the tracer. They're visible on the last photo.
Love those drawings Stephen. That last pic shows drill rounds alright, you can see the crimps in the small arms . Now I wonder if someone would like to produce the decals? 8)
Don't go by the markings on the photo at the bottom, they're not original. I'm guessing the rounds shown are drill rounds used in the sim, ie the turret drills trainer or were taken at Lulworth, the RAC Gunnery School, or the RAC Gunnery Wing in Hohne, Germany. The font is wrong and they're obviously transfers. I've put other photos on the Forum with the correct markings. The text on the diagrammes is correct.
As we are on the subject of shells, I found these old photos as I was going through my old albums, it shows me instructing the guys on how to use a shaped charge to cut through a shell, this one was inert. I will say no more other than good days 8)
Preping the charge and the shell.
Nice neat hole.
Nice neat hole.
Now if I've got the correct information ( or rather the information correct) the metadyne compartment and it's contents provided a very consistent reliable and infinitely variable dc current for the turret traverse and gun elevation/depression control.
The system seems to have been very troublesome in service, I would think that the access to the system compounded any problems, and looking through the armoured hatch/plate you can see why, I shall attempt to reproduce the basic components, although a fair bit of guess work will be required! 8)
Although a blurry photo you can see the amount of chunky cabling coming from the metadyne compartment and running off to the traverse contol.
That muzzle needs some rifeling.
I'm presuming that's the cabling that we can see and not hydraulic pipe work?
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi Phil,
More excellent work, do you still want all the batteries you mentioned or are some covered in this latest creation :-)
Dave
www.armorpax.net
Hi Dave , yes please I better have just four now, regards Phil.
I've made a start on the metadyne compartment. The big question......will it work? 8)
My bench is always a mess lately!
Lots more parts to add yet.
Vince, I've been looking at 3d printers to print these shells. What do you recommend I get, are the ultraviolet machines any good, can I run one with a normal laptop? So many questions! Ebay has a good selection of cheap machines that look like they could do the job.
