Continental UK only...
Shucks!
The only part of the turret that I have test fitted up till now is the turret base and that was when I was fitting the turret turn mechanism. I think you are correct when you say that the turret could be a big project so most probably I will start taking out the major components of the turret from the boxes and start preliminary test fitting parts when I get stalled on the hull roof.Have you done any test fitting with turret parts
You could be correct but still have not decided if I will be using the four bolts on top of the front bulkhead. I might just use the outboard ones only as I can't use the inboard ones with my homemade bullet ring.it will keep it more stable over rough terrain and relieve the stress from the side brackets
